what size you all running?
9 posts • Page 1 of 1
ive got 195 45 r15 and 50mm springs, will these rub at all?
what are you all using then?
- fiestasi1.4
I'm using a 195/45/15 tyre on a 7J ET35 rim using 55mm springs. No rubbing issues as such but the car is far to low and isn't nice to drive. Roll on my new 25mm springs
mines lowered 60mm with 195 45 r15, but rubbing isuses, but it aint a great drive that low. so im gunna get some30-40 lowering springs soon.
in fast ford or proformance ford, the other month i think it said something about how to work out the offset. well there was a topic on offsets. ill try and find the mag, and see what it says.
Dean
Dean
- mk3dean
i have genuine cossy rims on fez t but i did need spacers as the bottom of the shocks on the rear wear rubbin tyre so check b4 u drive. MATT
- Straight882003
hi bought ma car off this man! relised when i took 3 in back that wehenever a went over a little bump in road/speed bump my right back wheel goes !!! SQUEAK!!! i took it back to the man and he said its been lowerd 7cm!!!!! can this fail an MOT and how can n how much would it be to get it raised?
thanks
thanks
- joec2
