what would i need for 180bhp?
6 posts • Page 1 of 1
as above just wondering really [ERRR] i would need to do to a cvh to get a reliable 180bhp.while im here [ERRR] sort of power does a standard box take before it goes bang.
thanx zander
thanx zander
- zanderford
- Your car: zetec s,fiesta rsturbo project
Re: what would i need for 180bhp?
are you talking about a standard frst cvh lump ???
if so...
195 or stage two piggy back chip
beige 701 boche injectors
cossy or motorsport uprated fuel pump
larger intercooler
hybrid t2 turbo / hybrid t25 turbo or t3 turbo
that should do for about that bhp could get a bit more
gearbox should be ok for 200 bhp but won't last forever driven hard...
i put a new box in from ford in one of my frst that was running about 200 due to the fact i kept on buying boxs of people that where s**t and kept dieing, so just bite the bullet and bought one
but all depends how you drive and use the box tbh...
if so...
larger intercooler
- Pastieman
- Your car: Mk3 Fiesta Rs Turbo
yea was thinkinin frst engine wats the next stage after them bits.
is the escort turbo box any stronger?
- zanderford
zanderford :yea was thinkinin frst engine wats the next stage after them bits.
a std frst lump will take 16psi so head work and a cam then after then the block needs to come apart
all the erst box has is a lsd
- Ben_frst
as ben said the setup i said will run up to 16psi
then you are looking at low comp pisions... stronger con rods, lightend balanced crank etc... better flowing head
then looking at aftermarket or cossy management to run it, again injectors, fuel pump fuel pressure all have to be upgraded to suit....
be looking at what 220- 250 depending on setup maybe a bit more.
but then after this you would be looking at a zetec turbo or zvh as stronger units
all depends how deep your pockets are and what your looking for.... a day to day driver or a track or strip monster ???
- Pastieman
Pastieman :as ben said the setup i said will run up to 16psi
this is the time when you start thinking about spending money on the gearbox
- Pastieman
