Whats the best Cam for FRST??
5 posts • Page 1 of 1
Want to get a perforance Cam and tappets for my FRST. Can any one recommend some?[/quote]
Car is back...
- AndyBlackFRST
- BANNED SELLER
Piper make 2 FRST cam profiles specifically for T2 and T3 powered engines. Standard Ford cam runs out of puff around 6k which Piper have worked around, hence for better top-end power a high-lift cam may do the job better than standard Ford.
If you want to go to a T3 in the future, best thing to do is hold off getting a new cam till you get the T3 so you can get the matching Piper cam as the power band is shifted up the rev range to suit the T3's ability to blow harder at higher revs.
Wrong forum btw Andy - you should know better Sir
- Project
- fiftyoneCL
I have a Kent 31 cam with alloy vernier......works great. But needs set-up properly with vernier pulley and a session on the RR
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
