Whats the difference?
3 posts • Page 1 of 1
Between the cv joints/driveshafts of a 1.1 and a 1.6?
Between a cvh radiator and a zetec radiator?
The cooling fans mounted to the 1.1 hcs and 1.6 cvh engines?
- Brian
Driveshafts - The 1.6 ones are much thicker then a 1.0/1.1 shaft
Radiator - I think these are the same between CVH/Zetec, I can check later if you want?
Fans - If I remember correctly, wont fit as the HCS rad is different, and the fan is smaller.
- PaulC
