whats your ICE spec?
48 posts • Page 1 of 2 • 1, 2
Hi all, what ICE have you all got in your vehicle?
we always have engine and car spec...so lets have ICE
bassboy
bassboy
- bassboy
- Authorised Trader
Um ... Standard Stereo, 2 sets of standard front speakers and some poo 6x9's
Just took out my basic headunit, sub etc install out to put in my other car
- GeForce Junky
- Location: Gloucestershire Claims: To be FT's Sole Hillman Imp Launtic
Alpine 9855r Headunit
Alpine SPR-176A Componants In Custom Pods
0awg Cabling
300w Pioneer Componant Amp
Directed 1100d Bass Amp @ 1ohm
Lanzar Optidrive 1232d 12" sub (1400wrms)
Bassboy box coming soon
Lilliput 7.5" Touch Screen & Shuttle PC
0awg Cabling
- Shannon
Shannon :0awg Cabling
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
shannon...good spec mate will be even better once u get that box in there
right my spec goes a bit like this:
Pioneer 7500DVD Mk1 headunit/screen/dvd player
Orion 1600.2 - 420wrms x 2 @ 2ohms (runs my mids at 2ohms)...actually am feeding them 478wrms x 2!!
Rainbow CMX 465 extreme front components - 2 6.5" midbass and 1 set of tweeters
2 Orion D5000 amplifiers - 2500wrms @ 1 ohm @ 13.4v (mine are run at 14-14.4v so around 2600-2700wrms per amp!)
2 Orion H2 15" dual 2 subwoofers - 2000wrms each...im feeding them around 2500wrms if not more
Sub box is a 'bassboy' box with a letterbox style port...is about 6-7cuft and tuned in the LOW 30's FULLY braced internally and the usual bassboy touches
Cabling is taken care of the following:
split charge system, linking all batteries, charging lead etc is 1/0 gauge cabling! - 1/0 is just thicker than 0g
cabling into all my amps are 4 gauge via Connection fuse holders (1/0g in and 4g out) and d/blocks
speaker cabling is 12g Rockford Fosgate twisted pair cabling (9.41+VAT per meter!)...and there is about 30m of it in the car pimsle!
sub cabling is 8g power cable
RCA's are Rockford Fosgate white wolf RCA's - try £30+VAT per meter!! must be about 20m in the car!
power supply is taken care by 1 transit diesel battery in the front and 3
Optima Yellow Tops in the boot
180amp alternator
i THINK thats it LOL
bassboy
180amp alternator
bassboy
- bassboy
- Authorised Trader
JBL GTO-936e 3-way 300W 6x9 speakers
Head unit: Ministry Of Sound
# CDR/CDRW compatible
# RDS PLL FM/MW tuner
# 30 preset station memories
# Super bright white LED wide angle display
# Fold down full detachable panel
# RDS/EON
# 4 x 40W/Ch
# EQ system
(New Head Unit in 5 Days): Ministory of sound
* CDR/CDRW/MP3/WMA compatible
* PLL FM/MW Tuner
* RDS EON
* 30 preset memories (18 FM + 12 WM)
* CD Text
* ID3 Tagging
* MP3/WMA File
* M Bass sound system
* ESP anti-shock system
* ISO connector
* Bullet connector
* 4 channel high power amp (40w x 4 max)
* Detachable LCD display
* Unit dimensions (mm) 185 x 51 x 173
Door speekers
* 13cm (5.25") 2 way speaker
* Peak power: 135 W
* RMS power:45W
* Sensitivity: 89 dB
* Frequency response: 70 ~ 21 kHz
* Mounting depth: 61 mm
* Voice coil: 4Ω
* Cut-out diameter: 4-11/16" (120mm)
2 Subs
* IMPP CONE
* 50oz MAGNET STRUCTURE
* 2" KAPTION VOICE COIL
* POWER 120W RMS / 250W MAX
* FREQUENCY RESPONSE: 25Hz - 2kHz
* IMPEDANCE: 4ohms
* SENSITIVITY: 90dB
# RDS/EON
# 4 x 40W/Ch
# EQ system
* PLL FM/MW Tuner
* RDS EON
* CD Text
* ID3 Tagging
* MP3/WMA File
* ISO connector
* Bullet connector
Door speekers
* Peak power: 135 W
* RMS power:45W
* Voice coil: 4Ω
2 Subs
* IMPP CONE
* IMPEDANCE: 4ohms
* SENSITIVITY: 90dB
- JohnBoy_DIY
- Your car: CAR
alpine cda7873 head unit-oldie but goodie!!
fusion encounter front components-s**t but only 40 quid from halfrauds
day to day amp-vibe monobox3
day to day sub-vibe flitrap 10
bit of fun amp- DLS CAD11
bit of fun subs-2x 12inch alpine type S (soon to be replaced)
reason why i have 2 systems is
a)my 2 12s and dls are worth more than the car so don't get left in
b)weigh the arse end down loads and don't help handling, especially roundabouts etc
- martyc
Well I do have some ICE but its not installed
Sony M8800 HU
Standard si coax's
4AWG wiring
Audiobahn AW1200Q 700wRMS
Magnat Monoblock scoped @ 710wRMS
2.6cuft slot ported box tuned to between 35-38Hz
Mike
Sony M8800 HU
Standard si coax's
4AWG wiring
Mike
- diablosvy
My ICE install:
Sony CDX-M7850 Head unit
Sony XSF1334 13cm Speakers
(Maximum wattage - 160w
RMS input power - 40w)
JBL GTO-937 6x9's
(3 way speaker 100W RMS 300W maximum)
Sony XS-L122P5S SUB
(12" @ 200W RMS 1300W maximum)
JBL 6 Channel amplifier GTO 755.6 (560W MAX)
AUTOLEADS PC4-60 1200W Amp wiring kit
Not the best i know, but i like it
JBL GTO-937 6x9's
Sony XS-L122P5S SUB
- F1XTA
- Your car: Focus 2.0
Only just got my fiesta, so its not all in yet,
But,
Alpine CDA 9853, going upgrade shortly though
CDT Audio cl-51 audiophile speakers in front, but going for the £600 Eurosports soon
have CDT 6x9 comps in the shelf too, they may be coming out though, not decided yet
speakers are being ran of my West Coast Customs 1600.4, think its about 135 watt rms each side, that may even be at 12/13v too,
Then for the sub, West Coast Customs D5000 On my Orion H2 15(which is is a nice box, double skinned, braced inside etc) , Amp will be running around 2.5k rms i believe
got another D5000 too, not sure if i will use that on another H2 though,
Then ive just got an optima yellow top under the bonent,
soon will have 0awg running all through the car, then if i can get away with it, ill use 0awg direct into the amps with reducers on them
and possible split charge system
But,
- mikeysabes
mikeysabes :got another D5000 too, not sure if i will use that on another H2 though,
If your thinking about getting another D5000, taking the total power to 5kw then id seriously think about getting thicker wire than 0AWG, becuase once you start running a dizzy block your going to have to pass 2.5kw through 2AWG Enjoy your fire display
- diablosvy
we already have another D5000 mate, dont think im going to bother using it though
and if i do, it wont be running on 2awg, itll be 0 or 1/0
Mike
Mike
- mikeysabes
bassboy :i run 2 D5000's...might upgrade to 4 or 6 soon though
all run from their own 1/0 guage power cables and optima batteries
bassboy
F*cking crazy LOL
My one is enough, i am aiming for SQ though
- mikeysabes
How much do those Orion D5000 amps cost?
Ive got,
Alpine cda9821 cd player
Apline type r 6.5" component speakers in custom door pods
All good quality speaker cable
Maxima excide 900dc battery
IM using 2 ag and 4ag autoleads competition wiring kits (only one cable from the battery)
4 way autoleads gold distribution block
Amps are hidden behind rear quater pannels in metal cages
I have a 2 channel magnat ( i think) 2x80rms p0wering the front speakers
Directed 1100d powering subs. HAs to be run in slave mode so have to use headunit settings to control crossover as amp is damaged (off ebay, didnt test it in time)
two 15" alpine type r subs 500rms each, in custome sub boxes prorted with some drainage tubes and volume reduced with lots of cans of expanding foam.
I did have better amps, but my car got done over and had lots stollen, hence them now being hidded and in cages. Basicly all they left was my battery, cables, and sub cos the boxes were seriously strapped together, and too big to take out together!
Ive got,
- lucasdemoley
Ive got,
Ive got,
- lucasdemoley
Ive got,
Ive got,
- lucasdemoley
lucasdemoley :How much do those Orion D5000 amps cost?
Ive got,
[none gay] Anychance of a pic of your pods fella? [/none gay]
- Shannon
This is with the old speakers. Weigh a tone as i made them with fiberglass paste, its like 2 inches thick in some places!
- lucasdemoley
right i have got
sony low profile front door speakers (amped)
alpine sps690a 6 x 9 250w max (amped)
sony mdx m690 headunit i think it very good 4 by 52watts top of the range md player was it was issued cant find a better upgrade any one know of one please let me know!!
alpine 150w tweaters
2 12"sony sub 1100w max each
sony 1200w amp
sony dvd player and xvm h65 6.5" sony screen
4 awg cabling and loads
3 amps under a false floor all with fans to keep them cool. not a brillant set up but for a student and this lot costing under £700 i [ERRR] i done well consider the sony screen is £500 new when it was out
sony 1200w amp
- mattfiesta1987
jvc k - 11 head unit (summat like that)
pioneer 5.25 in front door speakers
infinity 6x9s in mdf and fabriced shelf
pioneer 12in 306c sub
toxic tx 600 amp fort sub
toxic tx 400 amp for 6x9s
need some back speakers and time to wire em to the headunit
- Jonezy
6x0s are crap dont get them!! as for speakers in the rear of the car not worth having them on [ERRR] music is recorded in left and right, not front and back, so if anything your guna have a s**t sounding system and it may sound louder but doesnt mean there is any quality
- bbl
bbl :6x0s are crap dont get them!!
Bit of a sweeping statement if you are referring to 6*9's that is
As with most things in life they are set up dependent. If you have no subwoofer then they can add some much needed bass, or they can be used as door speakers with a LPF, or as part of a surround sound system, the list goes on...
Mike
- diablosvy
Kenwood KDC-W7531 headunit
JBL 5.25" Component speakers
JBL 5.25" Coaxials
JBL GTO1200B- In Factory Ported box
Kicker KX-300.2 mono Amp, giving 300w RMS
Quite fancy adding a 4 channel amp, and having everything amped. At present my speakers are each getting 30w RMS from the headunit, that's 1/10th of the subwoofers power!
JBL 5.25" Coaxials
- richard_p88
jvc kd42i hu
kenwood components in doors
alpine type s 6*9s on parcel shelf
splx sub
stealth sub
4 gauge power cabling
twin splx mf 300 amps rewired to be just short of 300 rms one on each sub
splx sub
stealth sub
1.6 si coming soon
5 Door Register
5 Door Register
- Gazeddy
