Wheel centre hub problem?????????
Postby HAMMER26 on Fri Apr 27, 2001 6:06 pm
I have had to buy a new tyre 195/45 for me
fezzy,cause some b******d stuck a 3" nail
in it,but when i had a new tyre put on the guys at Elite said because ive got 6mm spacers on alround,the wheel doesn't go over
the centering part of the hub,and they are wright,so will i have to get something specially made or can i relly on the bolts
ligning up the wheel on the studs???????
any idea's lads
HAMMER26
Postby Project on Fri Apr 27, 2001 7:36 pm
Don't rely on the bolts - they may not be straight, which will really ruin your day when your car shakes itself to pieces or busts a bearing.
How about machining a circular spacer with a hole through the middle to accept a bolt, and use a nut to join it to the hub axle bolt (I know what I'm going on about!)
Umm.... how did you get the others on???
Project
fiftyoneCL
fiftyoneCL
