wheel ofset
7 posts • Page 1 of 1
wheel ofset
right im looking at a set of wheels for the girlfriend to put on her 206...
the ofset needed is 25, now if i were to get a set of wheels of ofset 35, would 10mm spacers make them 25 or 45?
cant remember which way it goes!
- xrsi
- XR(ustyAtTheMo)SI
To be honest mate you would be better off buying wheels that are the right offset from the outset. Spacers are always a bit of a frowned on way of achieving the result, although used coreectly they can work well.
yeah i know the ideal situation is to use the correct ofset and that large spacers do put more stress on components, however 10mm aint a huge spacer to be using and prob wouldnt have any extra effect over a correct ofset wheel!
only prob i can see is it catching cos it has a spacer to cahnge ofset....
- xrsi
- XR(ustyAtTheMo)SI
There are a few more issues than that mate but you are on the right track. If you can get spacers that have a locating ring as on the hub then you will probably be fine. Don't forget you will need longer wheel bolts/studs
yeah i know that about location rings on hubs/spacers, it stops shear forces acting on the nuts or bolts etc
yeah longer bolts are a must as otherwise it would only be held on by a couple of threads! NOT GOOD!
main concern really is how it would fit as opposed to a proper ofset wheel, oh and i still cant remember which way spacers go!?!
do they increase or decrease the number?
- xrsi
- XR(ustyAtTheMo)SI
- MAD_Adamski
- xrsi
- XR(ustyAtTheMo)SI
