wheel toe issue
wheel toe issue
Postby gazaboi on Mon Jul 06, 2015 10:01 am
Right first of all does anyone know what the degrees toe fiesta rs turbo lowered 30mm should be, as I've just fitted a set of poly bushed lower arms and been setting up my toe and I can't get it less than 50 degrees toe in as the tie rods are fully wound in on both sides. Nothing seems bent I've been using normal mk3 3 rivet ball joints since I've had it to make it have less camber and not had issues before not a clue what might be wrong or where to start looking
gazaboi
Your car: fiesta rs turbo
