where do i
3 posts • Page 1 of 1
where do i
tap a turbo boost gauge in to get a proper reading???
which pipe ect, as i dont want to put it in to the wrong pipe and ruin it
cheers..
cheers..
- FIESTArsTURBO
On the Left of the EFI You can see a small hose coming out, think it will be blocked at your fiesta RST using a rubber Plug.
Take off the plug.. put your gauge-hose on this connection..
And it will work.. It will measure the pressure in the inlet manifold.
It will also measure the vacuum in the inlet manifold when the gas-throttle is released..
This vacuum is also used to activate a Dumpvalve..
So the same connection can also be used (by using an Y-Splitter) to connect your Dumpvalve if needed
- Jur
