Where's the best place to put a ACT sensor
10 posts • Page 1 of 1
As above where would be the best place for it
Richard
Richard
BLUE OVAL OWNERS CLUB COME JOIN
- Richard_xr2i1800
Thank u very much mate , the ACT gauge measures the temp of the inlet air temp so it helps u to keep an eye on it as when it gets tot hot problems happen
Richard
Richard
- Richard_xr2i1800
T3 DAVE :yeah i know that mate
is there any need to know the air temp
i mean what can happern if the air temp gets to hot
Err, melted pistons?
If you know that as you say then you'd know that high ACT's mean that the car can cause detonation which is bad, as in holiest of holey piston bad!
- andyhardy
If you put it too close to the engine it'll absorb a load of heat and give false readings. My TDI setup was obviously nothing like yours, but you can hopefully work out where I put it from these pics. It's on the pipe just before the inlet manifold, but out in the open where it won't be subject to heat soak:
- GavStyli
- Your car: Fiesta Turbo
