Which Bass subwoofer to go with my system?
Postby RickDawson on Tue Nov 18, 2008 3:21 pm
I have had my headunit changed:
http://www.kenwood-electronics.co.uk/pr ... C-BT8041U/
The speakers (I only have fronts) have been changed (last Friday), but the new ones will not take as much bass as the Ford OEM ones, but sound more defined.
http://www.kenwood-electronics.co.uk/pr ... KFC-S502P/
As I have a lack of bass in my new speakers, I need some bass speaker.
I have the idea (as I don't want it to take up too much space) of this:
http://www.kenwood-electronics.co.uk/pr ... 0/details/
Are these type of subwoofers any good?
and where would it be put? under one of the front seats? in the front passenger footwell? by/on the side of one back wheel arch?
Rick Dawson
My car - mk5 Fiesta flight 1.3l
www.RichardDawson.co.uk - My Blog, with DJ mixes and other stuff (soon to add my car to it)
uk.YouTube.com/user/DJRickDawson - My YouTube Mixes, and slideshow for my car
RickDawson
Re: Which Bass subwoofer to go with my system?
Postby bassboy on Tue Nov 18, 2008 7:32 pm
your money would be better spent else where...my front end alone sounds bassier than what those active things do...the money you will spend on those, i would personally invest in a good set of components and an amp for them...also spend some money on sound deadening the doors and then see how it all adds up...trust me you would have more enjoyment from your music with the above setup than one of those active things...as a temp measure, you could also just deaden the doors with the existing equipment as it will get the most out of them for the power they run...
failing that, i would also heavily consider running a little 8" sub in the boot as i finished a Yaris today with a CDT sub and it sounded great for sucha little sub!!
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby RickDawson on Tue Nov 18, 2008 8:19 pm
I have the foam that's behind the door card. (which is sound deadening as such)
I take it you mean there's more that can be done?
Rick Dawson
RickDawson
Postby bassboy on Tue Nov 18, 2008 9:55 pm
the standard deadening is shocking...if you tap the outside of the car it will sound VERY VERY tinny...once the correct sound deadening has been applied, when you tap the door, it will sound solid...and not resonate in the slightest...
what you need to do, is seal up the doors as well as you can...this way the speaker will be playing into as close to a sealed enclosure as possible...bass will improve, the sound will have more depth, will be warmer, will just sound SO much better than a door with no work done to it...
have a look here how much sound deadening you can actually put in a car to help stop rattle teamspb-project-fiesta-box-finished-28-10-08-vt171080/
quick few pics of cars ive done...
outer skin covered
inner skin covered
on the yaris
and the minimum i would go on the inner skin
Have a look at the yaris install... teamspb-install-into-a-toyota-yaris-vt171973/ it shows how a simple install should be installed and gotten the most out of...
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby RickDawson on Tue Nov 18, 2008 10:12 pm
so the material is some sort of sound reflective, sticky backed foil?
How would I go about getting it done?
Rick Dawson
RickDawson
Postby bassboy on Tue Nov 18, 2008 10:42 pm
Yes mate..its proper sound deadening material...have a look here http://www.secondskinaudio.co.uk if there is a product that takes your eye...let me know and ill get you a price as im an authorised dealer
bassboy
bassboy
Authorised Trader
Authorised Trader
