WHICH CAM
5 posts • Page 1 of 1
WHICH CAM
Hiya chaps as some of you will be aware the plan to go zvh has been put on hold due to a damaged block so for the time being its going to still be the trusty CVH the spec of the engine is beige injectors, cossi pump, t3 turbo, scorpion s/s exhaust, 195 evo chip, -31 actuator and i am wanting to buy a uprated cam for it so im just wanting to know what you guys on here would recomend cheers
- andyb-rst
Re: WHICH CAM
I would use a newman cam heard really good things about them,I'm changeing mine to one.http://www.newman-cams.com/
- matty872
Re: WHICH CAM
Newman cams are meant to be very good, but I think you have to convert over to solid lifters with them, so beware of the extra cost
- Makaveli
Re: WHICH CAM
I was reccomended the Kent 34 Kit which gives good torque figures but Newman cams are very good!
New Project In Progress!
- mintwhiters
- Your car: Moved onto Motorbikes
