Which ib5 gearbox
Which ib5 gearbox
Postby rich1987 on Mon May 26, 2014 8:15 pm
Right ive basicly nackered my box in nocking and aint got loads of money to fit a cts or similar yet so was gonna fit a ib5 box there's loads of different information on this but not sure what to go for,
Which ib5 gearbox is best to fit into my frst zvh not fused about rear starter sure I can figure that out not keen on sorting hydraulic clutch but sure I can if need to any information would be great thanks
rich1987
Your car: fiesta rs turbo (zvh)
Re: Which ib5 gearbox
Postby Rhinopower on Mon May 26, 2014 8:46 pm
iB5 from a mk6 escort gti, with rear starter. Good ratios and the rear starter keeps it away from heat :)
Rhinopower
Your car: Volvo FH330
Postby rich1987 on Mon May 26, 2014 9:29 pm
Cheers chap is that a cable clutch?
rich1987
Postby rich1987 on Mon May 26, 2014 9:33 pm
No worries I had a look myself lol wasn't lazy, does it just drop straight in or is there any other modifications I need to do??
rich1987
Postby Rhinopower on Mon May 26, 2014 9:37 pm
You need the battery wiring to go with it but it's all plug and play. You will need to join 1 wire to your existing loom from the new one. You will need to use the rear starter too, the mount is different. Clutch cable yes!
Rhinopower
Postby Smo on Mon May 26, 2014 10:55 pm
You'll want a complete iB5 clutch. The release bearing is larger and has a flat bearing surface to interact with the rounded fingers of the iB5 clutch cover. Some people do it, but I don't recommend using an iB5 bearing on a BC clutch cover with flat fingers.
Smo
Postby rich1987 on Mon May 26, 2014 10:59 pm
So best to use a complete ib5 clutch then there is a few threads saying use just the release bearing but gonna fit a new clutch anyway so I'll just get a ib5 clutch and use that any recommendations for a clutch to take some stick?
rich1987
