White Fiesta RS Turbo - MOT Passed : Member's Gallery - Page 8 | Fiesta Forums
Re: White Fiesta RS Turbo - Updated 29/02
Postby mrorange2 on Wed Feb 29, 2012 1:34 pm
fiend - The coolent should go down abit once the car has started only put about 5 - 6 litres in the haynes says 7.1. I'm not that bothered about the colour of it really lol :P
Jay - It was about 10:30 last night when i was just trying to start it and i really couldnt be bother to do any fault finding so just left it i'm almost certain its the alarm i double checked all the battery connection and earth and all seem fine. It was all working great before i took it apart and i had some problem when i bought the car with the alarm so i just turned it off by the fob and never turned it back on again but now i have disconnected the battery it must have turned back on and the fobs dont seem to work. Ratty just txt me about the fuel cut off switch will check this tonight fingers crossed its that simple i did check all the fuses as well.
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby jayrs on Wed Feb 29, 2012 2:10 pm
dont blaim ya mate, i wouldnt of checked anything at that time of night too :lol: :lol:
if the alarm has played up before, then your prob right fella, get it ripped off mate
Postby jonyb4 on Wed Feb 29, 2012 6:09 pm
should see that coolant drop once it fills the block and head :)
the colours represent its life span, red/orange coolant lasts around 5 years and blue about 3
but nothing better looking than a aqua blue colour filling the tank :Q
looks stunning under there tim! very clean
keep a rag handy to keep it that way :P
Postby fiend on Thu Mar 01, 2012 12:48 am
jonyb4 :should see that coolant drop once it fills the block and head :)
I believe they came with red colour coolant when new, if your going for the original look.
Also who leaves the same coolant in for 5 years?
fiend
Postby jonyb4 on Thu Mar 01, 2012 1:58 am
haha exactly, mine barely lasts a year! :(
Postby jordan2litre on Thu Mar 01, 2012 2:52 pm
great job on cleaning the engine bay mate , what did you use ?? as my mates suggested wd40 and a rag , and i hit hit after trying ten minutes of it.
ive been told to avoid using a jet wash and a engine bay cleaner ?
jordan2litre
Your car: Fiesta mk3 SI 2.0L
Car: 1995 Ford 2.0 zetec
Postby mrorange2 on Thu Mar 01, 2012 3:20 pm
jordan2litre :great job on cleaning the engine bay mate , what did you use ?? as my mates suggested wd40 and a rag , and i hit hit after trying ten minutes of it.
I stripped the bay of mosts bits i could just leaving the block in place and i used come degreaser we have from my work which is awsome so i put this all over the bulk head etc and used a jet washer and a soapy spouge. I was amazed how well the gearbox etc came up after it as it was covers in black crap and its looking nice and clean now :)
mrorange2
Postby mrorange2 on Fri Mar 02, 2012 9:46 am
Had someone come out last night to have a look at the alarm and hes booked to come saturday afternoon to remove it :)
Quick question can you bleed or part bleed the brake system without having the engine running?
mrorange2
Postby rsturbonutter on Fri Mar 02, 2012 1:01 pm
No you not need the engine running mate
rsturbonutter
Your car: Fiesta RS turbo
Postby mrorange2 on Fri Mar 02, 2012 4:01 pm
rsturbonutter :No you not need the engine running mate
Cheers mate :D
mrorange2
Postby mrorange2 on Sat Mar 03, 2012 8:39 pm
I tried to bleed the brakes last night but it just wasnt working so took the master cylinder off and took it apart and i was shocked to see it was full of water and very rusty. I had bought this with the servo in good faith but it was rather pants cleaned it all up and put back together and still no luck so gave up for the night.
Started again this morning using a pressure bleed kit this did a better job and got air out the system but still no feel in the pedal.
By this time the alarm man had turned up as well as ratty to let a helping hand the alarm man disconnected the alarm but still no fuel pump we had 12v at the pump now but nothing else. The alarm was fully removed all wires etc then me and ratty took at look at the pump and with a wiggle of the wires and some jump leads on the battery the fuel pump came to live and she fired up :D :D :D sweet as a nut as well.
Next was to tackle the brakes tried to bleed them again but nothing so we took the master cylinder off and we put my old one back on which instantly felt better bled it form the cylinder first then used the pressure bleeder to get all the air out the system it was much better i think it need one more bleed to be perfect but least they worked.
Then i gave her a clean to get all the crap off her and she really needed it very pleased now just need to do the finishing touches now.
PS Anti freeze does NOT taste nice lol
mrorange2
Re: White Fiesta RS Turbo - Updated 03/03 Shes Alive!
Postby Ratspeed on Sat Mar 03, 2012 8:49 pm
You forgot the bit about twatting the fuel pump/sender with a hammer to make it work. They just cant teach that s**t! :lol:
Ratspeed
Postby mrorange2 on Sat Mar 03, 2012 8:51 pm
Haha to right mate cheers for the help again :)
mrorange2
Postby jonyb4 on Sun Mar 04, 2012 4:00 am
:lol: great stuff lads, glad shes running now tim, mot her and get her to FITP, i wanna see this beauty
she really has come a long way since that tired old thing you bought
Postby Ratspeed on Sun Mar 04, 2012 10:28 am
Your washer bottle cap is still the wrong way round. :rolleyes: :lol:
Ratspeed
Postby Excursion on Sun Mar 04, 2012 11:36 am
That looks great, really nice. Are the arch liners still to be fitted?
Postby mrorange2 on Sun Mar 04, 2012 12:48 pm
Cheers and yea they are how did u see they where not in lol. Got some brand new ones to put in today :)
mrorange2
Postby jayrs on Sun Mar 04, 2012 12:53 pm
front wheel arches mate, thats where i spoted thewy were missing
Postby jonyb4 on Sun Mar 04, 2012 2:41 pm
you can see fresh white paint in the arches :P
cap looks right to me, mine opens that way round
Postby Ratspeed on Sun Mar 04, 2012 6:15 pm
jonyb4 :you can see fresh white paint in the arches :P
Then yours is wrong too :)
Ratspeed
Postby mrorange2 on Sun Mar 04, 2012 8:50 pm
Well today was spent doing some finishing touches as well as servicing the engine and bleeding the brakes again.
Its booked in for an MOT next saturday so made sure everything worked which it did so i think shes now ready :D :D
New liners in
Almost finished
Just for Ratty
mrorange2
Re: White Fiesta RS Turbo - Updated 04/03 Few More Bits Done
Postby Dave G fsi on Sun Mar 04, 2012 9:50 pm
Looking stunning mate
Good progress aswell :Q
Dave G fsi
Your car: Mk1 FRS and FRST
Postby jonyb4 on Mon Mar 05, 2012 12:46 am
good stuff
mr ratattack... the flap on mine comes towards you and sits under the battery rim, which holds it for me, handy when pouring water in
Postby jayrs on Mon Mar 05, 2012 1:58 pm
excellent stuff mate.
one question though, how come you haven't repainted the batter tray where its gone rusty?
Postby mrorange2 on Mon Mar 05, 2012 2:45 pm
jayrs :excellent stuff mate.
It was on my list to do but just wanted to get it back together and MOT'd as that area is very easy to get to i will be taking the battery off and painting it myself. Its not really rusty though its been sanded and had a good coating of qurust on it so thats why its looks black etc.
Same with the small bits round the suspension tops they will get treated as well.
mrorange2
Postby jayrs on Mon Mar 05, 2012 3:25 pm
mrorange2 :
ah fair enough mate :)
Postby Ratspeed on Mon Mar 05, 2012 7:38 pm
jonyb4 :good stuff
Well yours is wrong, and why not use your hand to hold the lid back? :lol:
Ratspeed
Postby jonyb4 on Mon Mar 05, 2012 8:42 pm
were in a wireless era now mate!
Re: White Fiesta RS Turbo - MOT Passed
Postby mrorange2 on Mon Mar 12, 2012 9:58 am
On saturday it was in for its MOT and passed with flying colours no advisories very happy it was sooooooo nice to drive it again so just need to get some tax sorted when i actually have some money lol so she'll finally make it to a show this year :D :D
mrorange2
Postby jayrs on Mon Mar 12, 2012 8:12 pm
cool, glad to hear it went through with nothing mate :Q
Postby Dave G fsi on Mon Mar 12, 2012 8:39 pm
Excellent news mate, bet your over the moon! :Q
Dave G fsi
Postby mrorange2 on Tue Mar 13, 2012 10:03 am
To right i was over the moon :D just need to get some tax on it so i can have some fun lol
mrorange2
Postby jonyb4 on Wed Mar 14, 2012 12:29 am
it'll give your ST a run for its money :D
Postby mrorange2 on Wed Mar 14, 2012 12:04 pm
jonyb4 :it'll give your ST a run for its money :D
HAHA not sure on that one but we'll see my mates got a Clio 182 going to take it out for a run with him when its taxed lol :P :P
mrorange2
Postby - Danny Boy - on Wed Mar 14, 2012 8:39 pm
- Danny Boy -
Your car: Fiesta Si 2.0
