who can build my ultimate Zetec head??
22 posts • Page 1 of 1
Building a 2.1 zetec on throttle bodies and next is gettin a decent head done. porting,polishing,cams,bigger valves and 11:1 compresion is the plan at the moment. Who do YOU recomend??
Have already talked to Cylinder Head Develoment who gave me a fair price of aprox 600£+VAT for the work and parts.
Ennyone heard of this company??good or bad??fair price??
Recomend someone else for the jobb perhaps??
annything helps......cheers...
94 Ford Fiesta 1.8 16v xr2i
- Pisko
Andy form CHD did my head and his work is very good as he's been doing this sort of work for over 27 years, its the works and its also had the tappets enlarged to 32mm so i could fit wild cams, you might want to run higher compression than 11.1 but you would need forged pistons.
My zetec is a very high spec and will be putting out over 250bhp
- freak power
Andys work is one of the best i've seen when it come's to head work and the inlet ports are massive but mind you the head has been speced to my bottom end and the size of my throttle bodies, Zorst manifold and cam choice.
- freak power
34mm and 30mm
- freak power
http://www.raceline.co.uk
Ive got a raceline spec head, cams and bottom end and im well happy with it. I chose them cause they are meant to be the daddys at doing zetec's
- Sunil_FiestaRS_16V
Seeing as you clearly didn't hold back on this engine, what were your reasons for going for 34mm and 30mm rather than bigger?
Its the biggest valves you can get for the zetec
Custon one can be made, that my need mod in the future
- freak power
Oh, I could've sworn 36's could be used! Nevermind eh, it seems to work quite well *still no power output figures *
freak power :Andy form CHD did my head and his work is very good as he's been doing this sort of work for over 27 years, its the works and its also had the tappets enlarged to 32mm so i could fit wild cams, you might want to run higher compression than 11.1 but you would need forged pistons.
okay, prob gonna send my head down to CHD since I couldent find ennyone cheaper.
The specs on my engine at the moment is this:
2.1 litre zetec block
Forged pistons
Steel rods
Stronger crank bearings
lightened flywheel
omex throttle bodie kit
bigger fuel pump
4-2-1 manifoild and performance exhaust
With the right head work, how manny bhp should I hope for??
How mutch bhp is there to gain with higher compresion??
- Pisko
Forged pistons
Steel rods
lightened flywheel
bigger fuel pump
- Pisko
You better speak to Andy and tell him Andy Lindley sent you and ask about my head
- freak power
disc :Just a question...
Are 34mm and 30mm are standart Zetec valves? And from which engine?
A ST170 engine has 33.5mm and a 29.8mm ones but they are mad from 2 parts the valve head and the stem as mine are stainless steel machined form one bit of steel
- freak power
Twin 48mm throttle bodies, the head about with enlarged buckets to run race cams, steel rods, forged high comp pistons (13.5:1), 803 injectors mains and 250cc 2nd injectors 8 in all, full race manifold with a 1.7/8 inch bore 4-1 down to a 2.5inch system.
I don't think you get over 250bhp if you plan to use 11.1 compression and you didn't say you had forged pistons??
- freak power
Pisko, I have a set of NA forged rods and pistons for sale, see my PM for details. Mail be if interested, I won't be on here for a while.
what did you do to achive 13,5:1 compresion? Just the high comp pistons
or did you skim the head/cylinder aswell, and huw mutch?
Going to use forged pistons, but many people say this will only lead to
detonation. Getting a bit confused.
- Pisko
It was a mix of skimmed head, high comp pistons and a thin steel head gasket. You wont get any detonation if you run race fuel and a water/methanol vapor injection like me
Fitting forged pistons will hell
- freak power
