wht do i need to convert xr2i cvh into frst
10 posts • Page 1 of 1
i know i need the exhaust manifold, the turbo (is it possible to use t3 turbo on fiesta turbo setup?), intercooler, ecu, (do i have to alter my engine? eg pistons, valves, cam shaft etc. ) wiring loom, what else do i need?
your replys are appreciated thanks
- rwd xr2
Re: wht do i need to convert xr2i cvh into frst
would be easyer to get a turbo lump. as you would need low compresion pistons.
You can use the head off the xr2i tho.
- bernard
I dont know what the local law says but get a better brakes like RS2000 or cosworth...
- Medfin
- Your car: Fiesta Mk3
I think the xr2i brakes are the same as the frst [ERRR] ways
- bernard
thanks for your input but what i need to know is engine and runing gear wise please cuz i got my 4 pot calipers, lowered suspensions, poly bushes and custom made exhaust system so i need to know the best way to convert my xr2i cvh into turbo cvh and exactly what i need please thankyou
- rwd xr2
the custom made exhaust will need a new downpipe making as the xr2i downpipe does not have the provision to mount to a turbo.
basically this is what you will need to change your car to a 1.6 cvh turbo
FRST 1.6 cvh turbo bottom end or complete engine (xr2i head and inlet is same as xr2i - air charge temp is diff tho if using xr2i inlet)
FRST t2 and manifold OR ERST t3 and manifold, oil feed and return
FRST rad and intercooler (std or uprated)
FRST OFAB or OFAC engine bay wiring loom, ecu, and map sensor (OFAC is identical to xr2i but the xr2i map sensor will not work)
FRST coolant and boost hoses (+ cross over pipe if using t2)
FRST charge carrier
Best bet would be to find a fiesta turbo with crap body work and rip out all of the engine etc and swap it over that way selling the rest of the car to make some money back.
FRST charge carrier
- xrsi
- XR(ustyAtTheMo)SI
thanks alot mate that was very helpfull. i was thinking of finding an frst with rusty body work but i had a look around at some scrap yards and salvage yards and nothing at all. i got my exhaust made to accept the turbo. i was thinking of buying this special exhaust manifold which is possible to fit 2 turbos on it you can have a look at it at http://www.chevroletls1.com and i was wondering if that is possible to fit 2 turbos on a cvh engine ? how would it work? will it work at all?
- rwd xr2
Why? expencive for what. Yank engine's are like 4/5L so they can get away with it a 1.6 will just blow up if you twin turbo a frst 1.6cvh and race me i bet i win i only have one4wd xr2 :thanks alot mate that was very helpfull. i was thinking of finding an frst with rusty body work but i had a look around at some scrap yards and salvage yards and nothing at all. i got my exhaust made to accept the turbo. i was thinking of buying this special exhaust manifold which is possible to fit 2 turbos on it you can have a look at it at http://www.chevroletls1.com and i was wondering if that is possible to fit 2 turbos on a cvh engine ? how would it work? will it work at all?
- j7aoc
what if my engine is a 2L 16valve zetec can i twin turbo it then? do u think the engine will handle it? i just want to do some thing different. thats what modifiying is all about isnt it?
- rwd xr2
no basically you will not have enough flow to effectively twin turbo the engine on either a 1.6 or 2.0, if you did manage to somehow get decent pressure from both turbos then the engine wouldnt cope with the stresses unless they were both set to a really low boost pressure so just not worth it. Also it is enough of a pain to fit one t3 into the engine bay tidy never mind 2!!!!
stick to a sensible size turbo, if you want to be a little different to the rest get a gt series turbo as there arent that many been fitted to CVH or zetec engines at the mo so would be slightly different!
best bet would be to look on ebay for a scrapper.
- xrsi
- XR(ustyAtTheMo)SI
