will MK5a (rs2000) rear shocks fit the MK3 fiesta ??
8 posts • Page 1 of 1
I've been told MK5a RS2000 rear shocks (koni yellow) will fit the fiesta mk3.. they are shorter .. but will be a straight swap ..
koni's for the MK5 escort are less harder to find (2nd hand) here in holland.. and thus much cheaper (-:
.. koni's for Fiesta MK3 .. are nowhere to be found (2nd hand) in holland
Can anyone confirm ..or disconfirm it ??
- Jur
Hi,
I've heard that the rear suspenson of Escort Mk5a is the same as Fiesta Mk4, not Mk3.
I am not 100% sure though.
- wywywywy
DaveZetec :this may be correct, due to the cars using similar rear beams but ive not heard of it before
look at the top mount in a mk5a and compare it to a mk3 fiesta?
Top mount is the same..
- Jur
Re: will MK5a (rs2000) rear shocks fit the MK3 fiesta ??
Hi been a long time since you did this thread but just wondered if you found out if the escort shocks fit the fiesta or not? The reason I ask is I have some nearly new gaz coilovers for a rs2000 mk5a left over from an old project and now have a fiesta rs turbo with nasty g max suspension and thought if they would fit then why not make some use of them.Cheers for any help in advance.
- rsturbodaddy
Wow.. this topic is of 9 years back.. and still have the same fiesta.. but I have since then sourced several sets of koni yellow rear shockd for the mk3 fiesta.. so never tried the rs2000 ones.. even not bought a set.
So cant tell..
So cant tell..
- Jur
No probs mate will get the spanners out at the wkend and have a play if it doesnt fit will ebay it. Your fiesta is a beauty by the way.
- rsturbodaddy
Good luck fitting.. and thanx for the compliments
- Jur
