window not working
window not working
Postby gazaboi on Fri Jul 05, 2013 9:58 am
so my first thread is for my electric window not working on my fiesta rs turbo, ive checked the fuses there fine because its only my drivers side not working, its not the switch because i swapped them over and it still worked my passenger side, but i listened closer to my door and when i use the switch it does make a clicking noise in the door and it sounds almost like its stuck and wont go any help or ideas would be loads appreciated
gazaboi
Your car: fiesta rs turbo
Re: window not working
Postby mikeymikeyp on Fri Jul 05, 2013 11:47 am
pull off the door panel and see if your getting power to the motor if so then put power to the motor to see if its working
mikeymikeyp
Postby gazaboi on Fri Jul 05, 2013 3:20 pm
There's power going through, got the door card off yesterday and put a tester to the plug that goes to the motor and it has power going through it, but I don't know if it was right as when i turned on the ignition it read a power is constantly flowing, when you put the window to go up on the switch it sends the reader on the tester more than the tester shows and right down again to nothing the other way when i do the window down on the switch, i should probably add they seemed a bit tempermental when i got the car and the passenger window is a bit tempermental too
gazaboi
