wiring a sub to amp
9 posts • Page 1 of 1
wiring a sub to amp
i have a amp that at 2ohm runs enough power for my sub but my sub is 4ohm is there a certain way to wire it up or doesnt it matter
- chrislock
Re: wiring a sub to amp
if your sub is a single voice coil sub and runs at 4 ohms, then nothing you can do...this type of sub will have only one pair of inputs
if your sub is a dual voice coil sub, and each coil is 2 ohms, it can run at 2ohms yes... wire up all the positives together and connect to amp....connect all negatives together and connect to amp...et voila
bassboy
bassboy
- bassboy
- Authorised Trader
so if i was to run the 4ohm sub off the amp it wouldn give enough power
- chrislock
its a kenwood amp i would like to run a kenwood sub which kenwood sub would be the best for the amp the amp runs 500w at 2ohm
- chrislock
whats your budget fella? there is alot better out there than kenwood
bassboy
bassboy
- bassboy
- Authorised Trader
about £160 want the sub and amp to be the same brand and have at least 400 to 500 watts rms
- chrislock
is there any reason for that? there is no single manufacturer who makes the best of everything? its better if you run different brands as you get more for your money
bassboy
bassboy
- bassboy
- Authorised Trader
on that budget what do you reckon would be the best
- chrislock
Hi Chris, the best sub for your money would be something like the Ascendant Audio Arsenal 12" sub...its 500wrms, has got 18mm of xmax which is FAR more than most subs of similar money....not only will the sub play loud, it also plays very clean and precise...if you want more loudness, and get a ported box for the sub...you will get twice the loudness in general and you will have the ability to tune the sub how you want it to sound...
have a look here http://www.teamspb.co.uk/PAGES/ASCENDAN ... AUDIO.html under arsenal and for pics http://bladeice.com/arsenal.php
£170 RRP + P+P
I sell for £150 +P+P
bassboy
£170 RRP + P+P
bassboy
- bassboy
- Authorised Trader
