Wiring amp to all speakers?
7 posts • Page 1 of 1
Hey guys! mmm may sound stupid but i have a 1200w 1/2 channel sony xploder amp which i was using on my 2 mutant subs, but i would much rather have a desent all round loud but not bassy sound system, so is there any way of wiring the front two speakers and back two to the amp even though its only 2 channel and just forgeting about the subs??? Many Thanks Ryan
- rtlee88
You could try to replace the wiring but even then you are up against it as all the wires go through a sort of detachable interface between the car and the door.
So long as you are not running huge amounts of power into the doors why not get a wiring loom harness from halfords or somewhere and use the speaker plug to run the amp'd signal back through the original wiring loom? It solves your problem and I know each channel can take upto 400watt maybe more.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Alright mate! mmm i got my subs from a place called street racer where i live, but as far as i know they are the same ones that halfords has! the two 10inch i think subs in a carpeted box! yeah it sounds quite good for fairly cheap subs, however cause im using a 1200w amp they are a little too loud! you can barely hear your normal speakers!
- rtlee88
