wiring loom issues help please : Technical Problems / Queries | Fiesta Forums
Postby tat2cliff on Thu May 16, 2013 10:35 pm
it would appear that I may have a problem with my wiring loom, the problem appears to be between the ecu and the map sensor both the ecu and the map sensor have been replaced yet although I have had the car running it now wont start. There is a good strong spark but at times it seems to flood and other times the plugs are dry as if there is no fuel at all. Dose anyone know if this section of the loom can be replaced? or do I need a loom or alternatively dose anyone live near me in Croydon that may be able to help at a cost? I have spent a lot of money on this car but if I cant sort it I will have to break her which will be a real shame
tat2cliff
Your car: ford fiesta rs turbo
Re: wiring loom issues help please
Postby FRSJON on Fri May 17, 2013 6:27 pm
id unwrap that section of loom and check its condition cliff,if you can get the pins out the ecu/map sensor plug then the wires are easily replaced.. or cut near the plug,soldered/heat srunk.. but this was isnt the best
FRSJON
Postby tat2cliff on Fri May 17, 2013 9:49 pm
FRSJON :id unwrap that section of loom and check its condition cliff,if you can get the pins out the ecu/map sensor plug then the wires are easily replaced.. or cut near the plug,soldered/heat srunk.. but this was isnt the best
thanks jon can always rely on you mate for help
tat2cliff
Postby FRSJON on Fri May 17, 2013 10:27 pm
tat2cliff :
id come and do it for you if you were closer :)
FRSJON
Postby tat2cliff on Fri May 17, 2013 10:33 pm
the way things are going mate I might have to push to ya mate :lol:
tat2cliff
Postby FRSJON on Fri May 17, 2013 10:36 pm
FRSJON
Postby tat2cliff on Thu May 23, 2013 7:09 am
me and my son are gonna have a look at this loom at the weekend mate so hope your on line as may need to ask a few questions mate lol . Are you or jay going to santa pod mate?
tat2cliff
Postby FRSJON on Thu May 23, 2013 5:53 pm
tat2cliff :me and my son are gonna have a look at this loom at the weekend mate so hope your on line as may need to ask a few questions mate lol . Are you or jay going to santa pod mate?
for classic ford? no :( need to though as i have things to pick up :rolleyes:
FRSJON
Postby tat2cliff on Thu May 23, 2013 10:26 pm
what have you gotta pick up mate?
tat2cliff
