Wiring
15 posts • Page 1 of 1
Wiring
hi all
after much consideration ive decided to keep my 1.6 si and put a rs1800 lump in it but have been told that i will need to change the loom and ecu aswell.
to be blatent i have no clue about electronics and wiring.
how hard would it be to change them over with the si, is it a real ball ache
or is there anyone in the west midlands (dudley area) that can help me. i will of course pay for there time
regards
ricky
regards
ricky
- rickyjay86
Re: Wiring
If you've got and Si then you don't need to change all the wiring over, you can use all of the Si gear, you just need to run a CULT ecu as that is the only 130ps 1800 type which will work. Unfortunately they are like rocking horse s**t.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Re: Wiring
stick a 2l in mate you can use your loom and theres loads of mondeos around the scrappys to loot the ecu`s out of and its the same power as the rs1800
- dangerousdave
Re: Wiring
cant seem to find a cult ecu anywhere, do you no what prices they fetch and where from?
already got the rs1800 so dont really wanna go out and get another car (missis killing me i have 2 at home and 3 in a lock up :O)
- rickyjay86
Re: Wiring
Ah did I answer the same question that you asked sometime ago?
If you've got a donor car then yes just swop all the wiring, it will be less time consuming and cheaper than finding a CULT and also you will learn loads.
The first loom change I did took me about eight hours, but that will be much better than searching for and then having to pay through the nose for a CULT.
- Ollybee
Re: Wiring
i really have no clue when it come to electrical wiring. im a complete novice is it wise for me to attemp this. how will i no which wire goes where when i get it in the si??
(yep you answered something on similar line asked by me *thanks* you seem to have a mind of info*
REGARDS
RICKY
REGARDS
RICKY
- rickyjay86
Re: Wiring
As you strip it out of the RS label all the plugs and just don't forget to re-attach the earths and although it's time consuming it is quite an easy job, you'll learn a load mate and feel a genuine sense of achievement afterwards.
- Ollybee
Re: Wiring
after abit of perswation (spelling!) i think i may try it.
but if someone is close and would like to help i would be greatfull and will also pay for the time
- rickyjay86
Re: Wiring
well i took delivery of the rs1800 last night and there is no chance im getting the loom out
the cars in a bad state side on into a busstop drivers side grrr!
anybody no where i can get a cult ecu??? which car did they original come from???
regards
ricky
regards
ricky
- rickyjay86
Re: Wiring
They came from the Fiesta RS1800 Mk3.5. The reason they are rare is because they were only produced for nine months.
Some people have said they have had good results by using an early Mondeo 2.0l ecu, DEEP, DESK, DEWY and using the 2.0l MAF sensor. This way you can keep the Si wiring and use the Si engine loom. I've not done this myself so couldn't comment but other say they've had good results. But if you're going that far you may as well just put the 2.0l engine in it.
- Ollybee
Re: Wiring
could you tell me what year the 3.5 was made??
if i have a deep ecu and maf would it just plug and play with the rs1800 engine or is there more mods needed
as i already have these?
- rickyjay86
Re: Wiring
The really later RS1800 were M/N.
As I've said I've not run the 2.0l stuff on an 1800 as they are not designed to be used together but other say they have had good results. It would be just plug and play yes but as whether you will get optimum performance I couldn't say.
- Ollybee
Re: Wiring
thanks
will try these items while trying to sorce a cult ecu
and see how it goes
and see how it goes
- rickyjay86
Re: Wiring
If you cannot source a CULT ecu, then you can get an one of the MK3 RS1800 ecu's as long as you get an EDIS sensor wired in also.
- happypaul
Re: Wiring
Yes, the engine loom you have on the RS could be used with some pin changes.
- Ollybee
