Wishbone Question
5 posts • Page 1 of 1
Wishbone Question
I have converted my MK3.5 from a 1.3 into a rst, but i want to replace the wishbones, now do i use 1.3 wishbones or do i use rst ones?
- P-reg-Turbo
- Your car: P Reg Fiesta RS Turbo
Re: Wishbone Question
It'll be whatever wishbones were used for the hub carrier stuff.
If you've got the original stuff from the 1.3 for the steering etc just use those type again.
- DanFraser
As said if you changed them over for the conversion (not needed and wouldn't really advise)
Then you'll need mk3 if you left them as they were then ya mk3.5 wishbones will fit fine, mk3.5 driveshaft cv
Joint are meant to be of better design and the 1.3 shafts them selves are exactly the same thickness as turbo ones
Need any other questions answers feel free to pm me as you know iv done this conversion
Russ
Russ
- russ-RST
- Your car: fiesta rs turbo
i have used the original hub carriers, just changed the shocks, springs and brakes and shafts, will use the 1.3 arms again then,
Thanx for the help
Thanx for the help
- P-reg-Turbo
At the top of the tech section there is a thread about wishbones, I posted in it at the time with all the info you will need about wishbones that were fitted to the mk3 and 3.5 have a look at that fella
