wishbones do i really need to unbolt arm brackets??
7 posts • Page 1 of 1
stupid haynes book of lies..
it says about this torque to yeild buisness... is this for wishbones or brackets and if i want to be logical and not bother removing the stupid bracket then how would i proceed to tighten the wishbone bolts? with the weight on the ground or not?
just writing a list of everything that needs swapping for a reshell in stages, so i can keep both cars on the road as much as i can till the point of scrapping the si..
oh and just thought ide add if your wondering why im swapping wishbones the ones on the si are bearing jobs.
- JayC
Re: wishbones do i really need to unbolt arm brackets??
Do you mean the arm carriers?
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
yes mate thats the ones
- JayC
No they don't.
- Ollybee
You can do it either way, carriers in or out. I've never had the carriers out but I assume you can. I've never torqued the bolts either lol, reuse same bolts until tight + a bit more!
Ex Fiesta RS Turbo owner
- filtra
when i changed mine the bolts were shagged, all the threads had all been squished together. Besides you can get all new bolts for £10 from fords..
- Luke1990
feersum... i admire you!
BUT FOR THE SAKE OF A TENNER!!
to be honest i dont think my mechanic paid any special attention, the bolts are slighly rounded where hes mushed them.. again ive learnt ide proberly been happier if i done it myself (paranoia wise)
so ill just stick to the haynes.. i wont remove the brackets but ill tighten them as said.. apart from next when i do the reshell it wil be even lower so getting underneath when its on the ground might not be easy lol..
cheers chaps for yer helps
- JayC
