wossner high comp pistons zetec silvertop 2.1 NEW!
Postby RS1800-Cookie on Sat Oct 04, 2014 9:47 am
Wossner high compression pistons for 2.0 zetec silvertop 86mm new only few marks on one piston from going into bore other than that these are new and unused. In original box with rings and waist pins. Cost me over 560.00 will sell 520.00 ono
RS1800-Cookie
Your car: ford fiesta RS 1800
Re: wossner high comp pistons zetec silvertop 2.1 NEW!
Postby RS1800-Cookie on Mon Oct 06, 2014 9:36 pm
Anyone?? Before it goes on evil bay :devil:
RS1800-Cookie
Postby RS1800-Cookie on Sun Nov 09, 2014 1:40 pm
SFS anyone?
Offers
RS1800-Cookie
Postby RS1800-Cookie on Thu Dec 25, 2014 3:45 pm
Bump....
SFS open to sensible offers
RS1800-Cookie
Postby SLEEMAN on Thu Dec 25, 2014 9:21 pm
would love to have these for the price! will they fit into a st170 bottom end?
SLEEMAN
Postby RS1800-Cookie on Mon Dec 29, 2014 9:29 pm
Hi,
These pistons would fit your engine if you did the following,
1. bore the block out to 86mm (would have to do so anyway as oversize pistons)
2. use Silvertop forged rods,
the reason is that the silvertop rods are 136mm + 32mm crown on piston totaling 168mm
the ST170 is 139mm rods with 29mm crown on piston also making 168mm
Therefore from crank to top face of bore is the same.
hope this helps :)
RS1800-Cookie
Postby SLEEMAN on Wed Dec 31, 2014 12:54 am
can the silvertop rods be used on the st170 crank then?
SLEEMAN
Postby RS1800-Cookie on Thu Jan 01, 2015 7:14 pm
Yes they are the same size bearing same crank.
as long as you use silvertop rods these will be fine.
RS1800-Cookie
Postby RS1800-Cookie on Tue Apr 21, 2015 8:49 pm
SFS
Will take 400.00 cash as in hurry to sell and free up some money for my current build.
and before anyone asks no offers.
RS1800-Cookie
