Xr2 zetec project update 9/2 new gearbox n pics
Re: Xr2 zetec project update coilovers n brakes 30/10
300 i whent for 7 as the wheels n tires are soo small iv seen a few mk 2s runnin 175/55/13 with seven inch rear springs iv even seen them shorter they seem to sit just right . if not i have some 8" aswell
- rs-tom
Ahh right. Its just i know of someone who had 8 inch on there xr2 and fully wound up only just sat right.
On the mk1 i had to get 10 inch springs just to get the arch off the tyre
- Ratspeed
Are u thinking of fronts mate
- rs-tom
Yeah. ingnore me. im a retard Back will be fine
For some reason i thought you was on about fronts! What front spring you running?
- Ratspeed
Im not to sure mate
- rs-tom
gorgeous, the work your doing is amasing!
- rs-tom
coming together well mate
got a bit of a twist on the O/S/R braided brake line though
jayrs :coming together well mate
just checked it mate its not twisted there just so stiff
- rs-tom
- rs-tom
Re: Xr2 zetec project update lowered n new wheels fitted 31/10
the car is looking awesome,and those wheels set it off a treat i think you made the right choice. quick question how hard is it to do the wrapping on the bonnet?
- lachojski2005
this is literally car pawn.
although i got think the bonnet would look better red
- Michael!
my bad mate.
looking good mate i must say, as said before not a fan of black on wheels but im liking it
That looks the funlumps!
Camber on the front looks awesome too
- Ratspeed
- rs-tom
done a bit this weekend . getting bit cold in the garage now
removed the zaust manifold to weld the lamba in so hopefully she will be runnin better soon
wired in the gauges and plumed the oil pressure senser just have to weld the water temp sender boss in
made a really good job of the gauges all soldered n heat shrinked and theres just 2 plugs and u can remove the whole lot
made up 2 brace bars for the mondeo servo these have made a big difference i stamp on the break and the servo does not move this should improve brake feel .
top one
bottom one
also knocked up some floor mats for the footwells out of 2mm chequerplate
used heavy duty velcro to attach them to the floor so easy to remove to clean ect
thats all for now....
top one
bottom one
- rs-tom
Re: Xr2 zetec project update 14/11
awesome, looks soo cool
nice choice of wheel
keep up the good work
- rsonblackwheels
Cheeeeeeeers mate
- rs-tom
cracking mate
your missing a bolt on the coil pack too
really quality rebuild top work keep it up
- Rs Adz
Thanks mate
- rs-tom
Re: Xr2 zetec project update 27/1 mot,d :-)
Bit of an update nothing major accept passing it's mot no advisories
Iv done s**t loads but dont really have any pics
Found n fitted front screen
P clipped fuel lines
Got all electrics working everything works now
Made a cover for the hole in the back for the fuel pump
fitted tow strap
Adjusted mondy servo so pedals sit at propper hight now
Welded boss in magnex manifold for lamba
Gave the manifold a light polish
Cut the first silencer out of my magnex and replace it with pipe ( I did this for clearance purposes now my zaust ain't so low to the floor
Polished my tail pipe looks loads better was s**t up
Then had the tracking done and mot
Brought all new drainage plugs looks lot better plus I'd broken most of the originals
Ready for mot
Next thing is clutch release bearing as it's loud as feck n a bit of driving:-)
fitted tow strap
Ready for mot
- rs-tom
looking awesome mate!
loved the brake servo bracing and the foot plates
just read through this project/build, cracking job youve made of it
- b0yracer
- Your car: ford
Cheers mate it's nothing ground breaking but it's mine
- rs-tom
have you heppened to pop it on the rollers
be nice to see what its pushing out
Nah mate it's not that quick it ain't as quick as my standard frst . I think it's struggling to breath feels like its holding back
- rs-tom
hmm sensor to fault maybe?
its got the recipe to keep up with a standard RST, the 4 branch should free it up big time
the air intake temp sensor seems to play havok when they go wrong, Bic™ to replace though
Said before, ill say again
Car pawn.
Car pawn.
- Michael!
Update time
Right. Since mot iv did about 100 miles in 2 days the car was all good apart from the clutch
The release bearing was so noisy . I was pretty pissed off cuz I fitted a new clutch but forgot all about the bearing . Anyway I
Thought stuff it removed the box at the weekend and while it was off I sorced an LSD box and some vibratechnic mounts . Refitted all
Today done 40 miles all seems good . The box Seems a little noisy in 5th though
Anyway here s a few pics from my journey today
That's it for now I love the way it drives the brakes are really really good on the road
Next I need some kinda sunstrip as the sun can be a pain
- rs-tom
Re: Xr2 zetec project update 9/2 new gearbox n pics
Utterly sexy, I love this car.
Makes my mk2 look like a complete shed!
Gareth.
Gareth.
- black2
makes me wanna sling clarks car out the main workshop and get the xr2 in there!
LOL
stunning mate, very well put together, personally though can i recommend spacing the back wheels? just to even out the look
shall make it feel more sturdy at speeds
jony, he wont need to, you will be shocked how well these handle even on std stuff!
