Xr2 zetec project update 9/2 new gearbox n pics
Re: my xr2 project update 20/9 update
wow havent seen this before !
another mk2 on here
Lots of work going on - Never seen a throttle cable go through an air intake before ... very ingenius.
Love the clean carpet - excellent idea with the pressure washer
cool to see the home made tank - im using a new cfi fuel tank with external sierra cosworth fuel pump.
make sure you got no leaks between them welds !
another mk2 on here
- knuckles
- Your car: Fiesta Rs turbo
using my pictures tut tut !
fuel plump
fuel plump
- knuckles
Jay ur a legend . So do I run my live from my fuel pump relay to the fuel pump live and the sender is for the fuel gauge ?
- rs-tom
saw it after i had saved it, couldnt be arsed to change it
tom, yeah mate
tom, yeah mate
Knuckles tank don't leak I tested it after I whent round the welds with plastic padding tank sealer worked a treat
- rs-tom
rs-tom :Knuckles tank don't leak I tested it after I whent round the welds with plastic padding tank sealer worked a treat
im gunna braze/silver solder mine when i get round to it.
got a old Co2 fire extinguisher (dunno if that spelt right) that im gunna rig up to slowly pump C02 in there while doing the weld/braze, with any luck i wont blow my self up
Not checked this for a long time. Good progress there.
I done the zetec transplant to my mk2, if your stuck with some bits most things are covered in my thread.
I have a question though - whats your method for re-furbing the kit? Looks like new there in those pics.
Gareth.
Gareth.
- black2
i rubbed em down with 80 grit as some of the kit was badly weathered then 400 grit wet n dry they applied halfrauds bumper prep then halfrauds black bumper paint few coats then auto glym bumper restorer over that . looks good
- rs-tom
- rs-tom
Re: my xr2 project update 23/1 update
nice work mate
2 things, i see you cut the servo support brackets, im guessing you needed a higher angle??
also, what battery cover is that mate
Yes Jay I the reservoir has to sit level so cut a slither out the bracket then lifted the servo till res was level then took it off n welded it up . N the battery cover I dunno what it's off found it at the scrapper on the floor Cost me a quid
- rs-tom
interesting you had to mod it like that, i will have to double check it on mien when i come to it, ive not seen anyone else cutting it (unless i have missed it which is poss )
bargain with the battery cover then mate, prob find its off a tranny or something when clark eye balls it
Ppl use base spec mounts as they apparently don't need moddin
- rs-tom
Totally awesome.
Great work you have been doing there. RE the cyliner bracket, im sure ive read somewhere, although never checked myself, but a base model bracket dose not require modifying?
Are you running cosworth calipers with rs2k discs aswel?
Gareth.
Gareth.
- black2
Awesome looking XR2 mate. The engine install looks so clean.
Black2 - You don't need to mod non XR2 reservoir brackets for a MK1 mondeo servo
- MK2 Jamie
looking good keep up the good work
- Craig Hayter
- Your car: escort cosworth,fiesta rs turb
dunno about base spec brackets, thought thyey were the same.
my mondeo servo will sit alright on the xr2 ones though
oh and that battery cover, escort van mate, done the cam belt and fuel pump belt on ym dads van today and he had one the same
Battery cover fits bang on anyway mate . Rob ya dads
Breaks iv got brand new discs n fast road pads mondy servo and fresh fluid. We sill how they are before upgrading calipers
- rs-tom
dont need it mate, got brand new ones (fez ones)
Re: my xr2 project update update
well not done a hell of alot on the xr as i lost my job in january but recently started a new job on better money and my plans for the xr have changed a bit.
i live about 1/4 of a mile from donnington park and loving motor sport more n more everyday . we have a focus st and a 2lt mk3 fez as dailys so decided to build the xr into a road legal track toy nothing to serious or exspensive just fun around donnington and other tracks.
on the car side of things iv had bin sorting my garage out and doing body prep as i wanna spray the car myself
started off by building a bench as not having one is a killa . cost me nearly 2 weeks dole lol
n a good sort out
before
after
i
then started to prep the car wich i think is a mammoth task i know now why having a car painted cost so much
more stone chip
more prep
all sound deadening is up
thats it for now more wet flatting ect ect then primer .
n a good sort out
before
after
i
more stone chip
more prep
- rs-tom
makes ya feela good when the workshops all tidy and together, well does me anyway
preping a car for paint is one of the jobs i hate, but as you say thats why its expensive, as theres where the laubor is mainly, and the finished job is only as good as the prep put into it.
still coming on well there mate, it will all be worth it when ya done fella
you selling ay of the bits ya stipped out? like parcel shelf supports, rear belts etc? if so PM me with what ya got and prices mate, i will be after some bits for mine when i get cracking on it again
I wanna save the full interior mate but if I do break it up il pm ya
- rs-tom
no worries mate thats cool, was gunna ask about rear seat belts but i think i just found a set in the shed while digging out a mk2 fog light
still let me know mate, i will be on the hunt for some rear door cards at some point
nice work matey ive allways wanted a mk2
- xr2imetalhead
Re: rs-tom my xr2 project update 28th
done a bit more on the xr . done alot more bodywork that u cant see in the pics
also removed the dash i got a mate thats started doing electronicly charged flocking so decided to get it done as its grey and non of the rest is gonna be grey
aquired an omp roll cage and began fitting it not finished it yet
all mounting points beefed up with 3.5mm plate
then picked some road wheels up today il use these for road use and pots for track if all goes to plan
also got some 1.5mm ally chequer plate i will be using for door cards . hopefully gettin em flocked
should be gettin some paint on soon hopefully and also need to sort a harness bar
thats it for now
thats it for now
- rs-tom
as a man that dont do black wheels, im liking the rims
Looking very good mate
Brian
Brian
- Bkjames
Most impressive
- DAGET
- Your car: RS1800, 2.0s Orion
Re: rs-tom my xr2 project update strut brace door cards
bit of update iv finnished welding the roll cage mounting points in
also found a bit of rust so sorted that
not the neatest job will be ok when grinded back sealed n painted
cut and welded in a rear strut brace came out well i think
then door cards . got 1.5mm chequer plate from e bay cut it to size fitted well. il be gettin these flocked to
thats all for now . keepin busy
- rs-tom
looking good mate.
although i wouldnt of pop rivets the door cars one, thats gunna be awell annoying when you need to take one off
there not pop rivetted yet but dunno what else to use
- rs-tom
you wanna put some captive nuts in and some bolts mate, something like these http://cgi.ebay.co.uk/CAPTIVE-NUTS-8mm- ... 4833425bab
ot if 8mm is too big for ya, some 6mm ones http://cgi.ebay.co.uk/CAPTIVE-NUTS-6MM- ... 3a469fa211
bin busy this weekend . i had my first go at spraying with a spray gun
first started with the cage
bodge spray booth lol
happy with the cage it came out really well i think
then the inside of the car after hours of prep lol came out ok not great but its the inside n its clean
thats it for now . rear door cards n cage fitting next
- rs-tom
Re: rs-tom my xr2 project update cage and inside painted
looking good mate, cage came up well
