Xr2 zetec project update 9/2 new gearbox n pics
Re: Xr2 zetec project update coilovers n brakes 30/10
Postby rs-tom on Sun Oct 30, 2011 10:10 pm
300 i whent for 7 as the wheels n tires are soo small iv seen a few mk 2s runnin 175/55/13 with seven inch rear springs iv even seen them shorter they seem to sit just right . if not i have some 8" aswell
rs-tom
Postby Ratspeed on Sun Oct 30, 2011 10:15 pm
Ahh right. Its just i know of someone who had 8 inch on there xr2 and fully wound up only just sat right.
On the mk1 i had to get 10 inch springs just to get the arch off the tyre :cry:
Ratspeed
Postby rs-tom on Sun Oct 30, 2011 10:27 pm
Are u thinking of fronts mate
rs-tom
Postby Ratspeed on Sun Oct 30, 2011 10:31 pm
Yeah. ingnore me. im a retard :lol: Back will be fine
For some reason i thought you was on about fronts! What front spring you running?
Ratspeed
Postby rs-tom on Sun Oct 30, 2011 10:54 pm
Im not to sure mate
rs-tom
Postby jonyb4 on Sun Oct 30, 2011 11:03 pm
gorgeous, the work your doing is amasing!
Postby rs-tom on Sun Oct 30, 2011 11:07 pm
Thanks mate :-)
rs-tom
Postby jayrs on Mon Oct 31, 2011 12:34 am
coming together well mate :Q
got a bit of a twist on the O/S/R braided brake line though
Postby rs-tom on Mon Oct 31, 2011 9:03 pm
jayrs :coming together well mate :Q
just checked it mate its not twisted there just so stiff
rs-tom
Postby rs-tom on Mon Oct 31, 2011 9:04 pm
update
got the brakes bled today and lowered it with new wheels on
just took some quick pics on ma phone so pics not to great
still gonna lower front another 5 or 10 mm
im happy with the wheels they look great
thanks
rs-tom
Re: Xr2 zetec project update lowered n new wheels fitted 31/10
Postby lachojski2005 on Mon Oct 31, 2011 11:05 pm
the car is looking awesome,and those wheels set it off a treat i think you made the right choice. quick question how hard is it to do the wrapping on the bonnet?
lachojski2005
Postby Michael! on Mon Oct 31, 2011 11:07 pm
this is literally car pawn.
although i got think the bonnet would look better red :(
ft-com-members-map-vt190192/
Michael!
Postby jayrs on Mon Oct 31, 2011 11:08 pm
my bad mate.
looking good mate i must say, as said before not a fan of black on wheels but im liking it :Q :Q
Postby Ratspeed on Tue Nov 01, 2011 7:09 pm
That looks the funlumps!
Camber on the front looks awesome too :Q
Ratspeed
Postby rs-tom on Tue Nov 01, 2011 7:49 pm
Cheers mate
rs-tom
Postby rs-tom on Mon Nov 14, 2011 9:35 pm
done a bit this weekend . getting bit cold in the garage now
removed the zaust manifold to weld the lamba in so hopefully she will be runnin better soon
wired in the gauges and plumed the oil pressure senser just have to weld the water temp sender boss in
made a really good job of the gauges all soldered n heat shrinked and theres just 2 plugs and u can remove the whole lot
made up 2 brace bars for the mondeo servo these have made a big difference i stamp on the break and the servo does not move this should improve brake feel .
top one
bottom one
also knocked up some floor mats for the footwells out of 2mm chequerplate
used heavy duty velcro to attach them to the floor so easy to remove to clean ect
thats all for now....
rs-tom
Re: Xr2 zetec project update 14/11
Postby rsonblackwheels on Wed Nov 16, 2011 8:46 pm
awesome, looks soo cool
nice choice of wheel :Q
keep up the good work
rsonblackwheels
Postby rs-tom on Fri Nov 18, 2011 9:09 am
Cheeeeeeeers mate
rs-tom
Postby jayrs on Fri Nov 18, 2011 10:33 am
cracking mate :Q
your missing a bolt on the coil pack too :bonkers:
Postby Rs Adz on Sun Dec 11, 2011 10:16 pm
really quality rebuild top work keep it up
Rs Adz
Your car: xr2i and mk1 fiesta
Postby rs-tom on Mon Dec 12, 2011 9:29 pm
Thanks mate
rs-tom
Re: Xr2 zetec project update 27/1 mot,d :-)
Postby rs-tom on Fri Jan 27, 2012 7:59 am
Bit of an update nothing major accept passing it's mot :-) no advisories
Iv done s**t loads but dont really have any pics
Found n fitted front screen
P clipped fuel lines
Got all electrics working everything works now
Made a cover for the hole in the back for the fuel pump
fitted tow strap
Adjusted mondy servo so pedals sit at propper hight now
Welded boss in magnex manifold for lamba
Gave the manifold a light polish
Cut the first silencer out of my magnex and replace it with pipe ( I did this for clearance purposes now my zaust ain't so low to the floor :-)
Polished my tail pipe looks loads better was s**t up
Then had the tracking done and mot :-)
Brought all new drainage plugs looks lot better plus I'd broken most of the originals
Ready for mot
Next thing is clutch release bearing as it's loud as feck n a bit of driving:-)
rs-tom
Postby jonyb4 on Fri Jan 27, 2012 11:31 am
looking awesome mate!
loved the brake servo bracing and the foot plates :Q
Postby b0yracer on Fri Jan 27, 2012 12:10 pm
just read through this project/build, cracking job youve made of it :)
b0yracer
Your car: ford
Postby rs-tom on Fri Jan 27, 2012 12:37 pm
Cheers mate it's nothing ground breaking but it's mine :-)
rs-tom
Postby jonyb4 on Sat Jan 28, 2012 12:33 am
have you heppened to pop it on the rollers
be nice to see what its pushing out
Postby rs-tom on Sat Jan 28, 2012 8:07 am
Nah mate it's not that quick it ain't as quick as my standard frst . I think it's struggling to breath feels like its holding back
rs-tom
Postby jonyb4 on Sun Jan 29, 2012 1:05 am
hmm sensor to fault maybe?
its got the recipe to keep up with a standard RST, the 4 branch should free it up big time
the air intake temp sensor seems to play havok when they go wrong, Bic™ to replace though
Postby Michael! on Mon Jan 30, 2012 3:29 am
Said before, ill say again
Car pawn.
Michael!
Postby rs-tom on Thu Feb 09, 2012 5:28 pm
Update time
Right. Since mot iv did about 100 miles in 2 days the car was all good apart from the clutch
The release bearing was so noisy . I was pretty pissed off cuz I fitted a new clutch but forgot all about the bearing . Anyway I
Thought stuff it removed the box at the weekend and while it was off I sorced an LSD box and some vibratechnic mounts . Refitted all
Today done 40 miles all seems good . The box Seems a little noisy in 5th though :-(
Anyway here s a few pics from my journey today
That's it for now I love the way it drives the brakes are really really good on the road
Next I need some kinda sunstrip as the sun can be a pain
rs-tom
Re: Xr2 zetec project update 9/2 new gearbox n pics
Postby black2 on Sun Feb 12, 2012 1:16 pm
Utterly sexy, I love this car.
Makes my mk2 look like a complete shed! :rolleyes:
Gareth.
black2
Postby jayrs on Sun Feb 12, 2012 1:27 pm
makes me wanna sling clarks car out the main workshop and get the xr2 in there!
Postby jonyb4 on Sun Feb 12, 2012 6:25 pm
LOL
stunning mate, very well put together, personally though can i recommend spacing the back wheels? just to even out the look
shall make it feel more sturdy at speeds :)
Postby jayrs on Sun Feb 12, 2012 7:21 pm
jony, he wont need to, you will be shocked how well these handle even on std stuff! :D
