Xr2i 1.8 16v to 2.0 zetec quick question/advice
7 posts • Page 1 of 1
Hi, i have recently purchased an Xr2i which has had a 2.0 zetec engine from a mondeo put in it.
Firstly i noticed it was still registered as a 1.8 on the log book. I wanna get this changed to the correct 2.0 ltr for insurance purposes, is it a case of simply telling the DVLA to get the log book changed?
Also its still running drum brakes on the back. will this cause a problem with braking due to the higher power? i've had it out and it seems to brake ok with drilled and grooved disks on the front but under heavy braking they do start to smell a little ( i've only heavily stopped once by the way )
i'm considering swapping the rear axel for a rs turbo one with the disc brakes.
Any advice or comments would be much appreciated.
Swiss
Swiss
- Swiss
Re: Xr2i 1.8 16v to 2.0 zetec quick question/advice
Discs brakes did not comes as standard on the RS or any other mk3 for that matter, It's also not worth upgrading as the drums are more than capable of dealing with whatever you can throw at it. If you are into spirited driving you might want to upgrade the fronts though as this where most of the cars braking is done. Also the chances are that the RS turbo rear bean will be the same as the 2i anyway.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Ah i see, wasn't aware of that. thanks.
i take it when you say upgrading the brakes you mean bigger discs and calipers? The car i got came with very little if any service history. theres nothing about the conversion so i don't know whether it was a cowboy job or done properly. the guy i brought it off said that the previous owner had done the conversion.
The car seems to run fine, no problems at all and according to the previous owner it never caused him any problems apart from haviing to change the engine mounts as they were fcuked. I just like to make sure everythings as it should be (hence log book change and that)
Do you know of anything else i should look out for?
- Swiss
dont worry swiss im still running drums on the backon mine and they are fine. its all about the front brakes
if u want to change them get some of these, they are piss easy to fit and they stop mine good enough
extensive-cossie-brake-fitting-guide-large-download-pics-vt29615/
- Mikee_RS
Car: 1995 Ford Fiesta
Cheers Mikey, i'm still learning about all this lol
dunno if i'd need to change just yet, just making sure that what i've got is sufficient really. last thing i wanna do is end up in a bush somewhere!! haha
might have a go at them mirrors i was on about this weekend. I've prepped them properly this time (i think) unlike that grille we did last year!!! haha
You still doin santa pod in april? wouldn't mind seeing ahat this thing can do on the 1/4 mile
- Swiss
- Mikee_RS
yep just do a straight forward brake conversion at the back replace the drums with the discs loads of online stores sell rear disc conversion kits try this one http://www.europerformance.co.uk/ ... as for the smell of ur brakes on the front its normal and if you did heavy braking then dnt worry bout it or http://www.rimstyle.co.uk
tha bizz.
- xr2i 1.8 16v d.o.h.c
