XR2i 16V - ABS?
5 posts • Page 1 of 1
XR2i 16V - ABS?
Can anyone tell me if the 16V version of the XR2i has ABS or not?
Thanks.
Thanks.
- Vaughny
- Your car: Carless!
Might have been an optional extra?
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
How do ya change it wooshy! didnt know that was possible do tell
CheeRS
Bob The Builder
ELM_US gone but never forgotten!
CheeRS
Bob The Builder
- Bob The Builder
- Yes He Can..!
Hi,
You adjust the ABS by adjusting how slack/tight the ABS Modulator belt is.
you do this by adjusting two bolts.
http://i108.photobucket.com/albums/n1/Wooshy_mike/Picture_001.jpg
Undo Bolt A slightly and then undo bolt B in the picture, then move bolt B "backwards" Or "Forwards", Tightening or Slacking the belt.
Having the belt tight means the ABS is quite egar.
If its quite slack then quite the oposite happens and you can travel further down the pedal before the ABS kicks in, If its too slack then your ABS light will be on perminatley,
I hope this helps.
Mike.
I hope this helps.
Mike.
Project W
XR2i? You bet!
XR2i? You bet!
- Wooshy
