Xr2i 8V
6 posts • Page 1 of 1
Beat me too it by a few days All costs at lot for not much more power tho, may be better off dropping a bigger engine in or even a turbo lump.
- JamieFRST
- Keep It Tidy
Unless you are running a lot of power a diesel gearbox will slow you down, not speed you up.
They require more torque!
IF you are looking to change your gearbox I recommend for an XR2i you consider an RS1800 box instead, good ratios and stronger box.
- Stoned
Stoned :Unless you are running a lot of power a diesel gearbox will slow you down, not speed you up.
Whuh!?
The ratios are slightly longer or the same as the XR2i 8v ratios afaik, so it won't really slow you down. There isn't any more transmission power loss.
The difference is the diesel box is about 800rpm lower at 70 in 5th gear.
- Project
- fiftyoneCL
