xr2i brake upgrade and kn filter.
11 posts • Page 1 of 1
i have now recently bought a 2i in moondust silver on a j plate.
i wish to fit bigger brakes i remember seeing on here that sierra 4x4 calipers fits.
what brakes fit with little mods i dnt mind spacing them.
also i have no airbox i wish to fit a kn filter but i dnt know what i need all i have is the big plastic bit that cums from the efi unit the air intake.
any help would be good.
does anyone know if my xr2i comes standard with a lower strut brace?
- mattfiesta1987
Also they require the fitment of 15" wheels and even then they can be incredibly tight. We had to remove the wheel weights and have them balanced another way as they fouled on the caliper.
The K&N induction kit has everything you need to fit it all you will need to do is make sure you get the right one as there are two listed. One is for the Hitachi ISCV equiped car and the other is for the Webber ISCV equipped car. Seeing as the Webber type would be attached to the airbox lid and you say this is all missing it would make sense for you to have the Hitachi valve. Post a pic of your bay so we can identify this before you part with money
You need to put the weights back on just they go on in a different place to clear the caliper. You can't drive with unbalanced wheels it would be horrible
so jut move em owards the inside of the rims, right i get you, i thught it would be wierd. i want some just for the looks of having huge brakes.
maybe once i get a bigger engine and master cylinder.
- Jonezy
hi guys thanks for that. i will get a pic of my engine bay and let you all know.
i have seen the a sierra 4x4i would these calipers fit i belive it is a 90 spec it in a local breakers yard.
- mattfiesta1987
now tried to load my pics up and i cant 4 sum reason is there any way i can look and see is there like a stamp or summit.
- mattfiesta1987
