xr2i carbd
5 posts • Page 1 of 1
xr2i carbd
think bout converting my xr2i 2 carbs as ive got a set of twin 40 delortos sat here and its sumthing different wot wud i need 2 do as i have a manifold for them would i just need a regulator 2 slow the pressure down
- Shreevy
also,possibly an uprated fuel pump facet red/silver top.im slapping twin dcoe40's on a XR3 lump,but as it was a carb'd engine it makes life a little easier.haven't really heard alot about turning injection to twins.
- PMK3
The problem you will have there is that the XR2i head has cut outs for the injectors; so this means that when you try to fit the webber manifold there will be a gap, so unless you know somebody that can weld in the head cut outs, you will need to change the head.
Have a look at the link below to see what I mean:
You need to read the bit were the title is IDENTIFYING ENGINE TYPE
http://www.pumaracing.co.uk/cvh.htm
Well its says this actually:
89SM6090 - The EFi hemi head from Bosch L Fiesta XR2i's and XR3i's. Also has the injector cutouts in the inlet ports and therefore won't take a DCOE manifold without welding or other tinkering. Good head for big valves though as the port walls are very thick and the port shapes are excellent for flow
- BLOGGY
