xr2i engine
7 posts • Page 1 of 1
xr2i engine
hi ive got a mk3.5 1.3 hsc cfi engine and i want to put an 8v CVH 108bhp EFI xr2i engine in what would i need apart from engine box and loom
- fiestamk3.5
Re: xr2i engine
fiestamk3.5 :hi ive got a mk3.5 1.3 hsc cfi engine and i want to put an 8v CVH 108bhp EFI xr2i engine in what would i need apart from engine box and loom
Fuel pump, manifolds, exhaust system, radiator and hoses, fuel lines
John
Audi quattro turbo
- bowdenj
by manifolds do u mean inlet and exhaust and is that everything i would need
also wouldnt my current exhaust be ok its decated couldnt i just swap down pipes
- fiestamk3.5
fiestamk3.5 :also wouldnt my current exhaust be ok its decated couldnt i just swap down pipes
no you can't, becuase the xr2i has a larger bore exhaust, and different downpipes, so they wouldn't fit together
- musicdrummer42
i no the downpipes are different and so is the backbox put are the middle sections on the xr2i any wider then my standard ones because if not surely i could have a different down pipe attached to the midsection and use my bigbore at the end
- fiestamk3.5
fiestamk3.5 :i no the downpipes are different and so is the backbox put are the middle sections on the xr2i any wider then my standard ones because if not surely i could have a different down pipe attached to the midsection and use my bigbore at the end
Trust me, the entire exhaust is different
John
Audi quattro turbo
- bowdenj
alrite fair enough was just hoping could get away with not swapping it all to save a few quid for other parts so is everything above all i need for the conversion
- fiestamk3.5
