xr2i head
xr2i head
Postby flyer1 on Sun Jan 22, 2006 3:32 pm
just bought an fiesta turbo, the head gasket has gone , when removing head there is a big score between to pots , can any 1 tell me if a xr2i head will be suitable the engine is a 1600 boared out and ive noticed on the block it has these like copper rings around the out side of the bores is this common on these engines thanks in advance for any imfo cheers
flyer1
Postby j7aoc on Sun Jan 22, 2006 3:37 pm
The xr2i 100% the same head and im sure so is the cam. When doing a head gasket most time's the head will need a skim which done by a good company is ok and make sure it just a small skim as it will highter the compression in the engine :wink:
j7aoc
Postby flyer1 on Sun Jan 22, 2006 5:14 pm
so it shount affect the compression ratio or any thing valves the same ect old head got piper cam and lifters so proberly put them in new head just wanted to make sure they were the same before buying cheers
flyer1
Postby XR2RST on Wed Jan 25, 2006 12:43 am
As far as i no thexr2i head will bolt on but the valves are designed to withstand higher temperature on the turbo head and i thought the cam would av been designed for the turbo
XR2RST
Postby paradox on Wed Jan 25, 2006 2:33 pm
you can use the xr2i head but you need to fit the turbo cam
paradox
Postby flyer1 on Wed Jan 25, 2006 6:10 pm
right bought the head now any way striped it all out except valves put cam lifters spring ect off old head in same order , going to be fitting it tomoz if whethwer holds off ill let u know how i get on , still no imfo about theses copper like rings around the bores
flyer1
Postby flyer1 on Wed Jan 25, 2006 6:18 pm
might be able to see them here not sure
they sit where u can see the shiney bit outside the bors there like copper rings in a grove in the out of the bores
flyer1
Postby turbodaily on Wed Jan 25, 2006 6:39 pm
turbo heads have sodium filled valves where as the xr2i heads dont
my old frst: 185bhp @11psi stage 1
my new frst: unknown...
turbodaily
Postby jayrs on Thu Jan 26, 2006 12:06 am
head and cam on xr2i are the same as the FRST, 100%.
i thought the cam was different untill i called fords a while back to get a price, thats when i was told to get a s/h head inc cam off a 2i (as cam was about £150) as they are the same, double checked this when i went down for some bolts, and sure enough, part number is the same for both.
turbodaily :turbo heads have sodium filled valves where as the xr2i heads dont
turbodaily, ive heard this before, from what i remember this only applied to the S1 ERST, might be others but not the fiesta dude
Postby flyer1 on Mon Jan 30, 2006 5:47 pm
finnally done put the new head gasket on today fire her up , only fireig on 2 after alot fking arond to rocker cover back off and 2 valves had the threds striped on the rockers so replaced these , started her up and she a bit rattley top end so give her a rev for a whle and shes quitend down a bit , but still to noisey , so gave her a blast up the road the t3 was boosting upto 0.5 and she was quick on tick over she sounded fine but as soon as i rev her she rattles do u think the lifters could be fked
flyer1
Postby jayrs on Mon Jan 30, 2006 7:20 pm
yeah sounds like the tappets have had it, common prob mate, car will drive ok but they make a lot of noise thats all.
dont get dicked on price for them though, i got some power train ones from parco and they wasnt even £40,
Postby Project on Tue Jan 31, 2006 4:22 am
Sodium-filled valves only on ERSTs (and I'm not sure if it was just the S1 head or both S1 and S2, altho iirc Microrat lists them for the S2 head).
Everything else seems to be the same - even cams according to Microcat/tech info, just gasket tightening torque settings vary in places.
Project
fiftyoneCL
fiftyoneCL
Postby flyer1 on Tue Jan 31, 2006 9:20 pm
got a set of lifters £21 off a m8t in the trade put them in and still rattleing
think going to change cam see if that helps
flyer1
Postby jayrs on Wed Feb 01, 2006 7:12 pm
Project :Sodium-filled valves only on ERSTs (and I'm not sure if it was just the S1 head or both S1 and S2, altho iirc Microrat lists them for the S2 head).
the head, cam, tappets, valves etc are all the same :wink:
flyer1 :got a set of lifters £21 off a m8t in the trade put them in and still rattleing
nice touch for the price mate.
when you say you still have a rattle, have you tried slacking the rocker arms and re tightening them, this worked for me, also did you soak the new tappets in oil for a few hours? they say 24 hours but ya dont need to do it that long, 30 mins would be enough really, as long as there submerged.
Postby flyer1 on Thu Feb 02, 2006 12:43 pm
i did soak them for a while but not long , just hoping its not big end rattle
fingers crossed
flyer1
Postby Project on Thu Feb 02, 2006 5:45 pm
The cam AND tappets on the CVH must be changed at the same time for new items - you can't mix and match new with old (and definitely not old with old!).
/al
Project
fiftyoneCL
fiftyoneCL
Postby jayrs on Thu Feb 02, 2006 7:36 pm
Project :The cam AND tappets on the CVH must be changed at the same time for new items - you can't mix and match new with old (and definitely not old with old!).
/al
ya right but ya also wrong, as long as the cam isn't fooked you can use new tappets on a old cam, i did, my mate did, loads of people do all the time, and they never had problems, lets face it, unless you wear the base of the tappet they get nosiey, but work the same as new ones.
Postby Project on Fri Feb 03, 2006 9:31 am
You're right - it's possible, but with all due respect Jay, mixing old and new on the CVH is asking for trouble, pure and simple. It accelerates the wear on the cam and tappets.
I just don't see the point of adding a load of very hard, fine swarf into the oil system you inevitably get from a cam/tappets wearing fast.
Guess we'll just have to agree to disagree on this one :)
Project
fiftyoneCL
fiftyoneCL
Postby flyer1 on Fri Feb 03, 2006 2:01 pm
is there away of testing to see if its big end rattle or cam cheers its fine on tick over but soon as rev it rattles like fck
flyer1
Postby jayrs on Fri Feb 03, 2006 3:36 pm
Project :You're right - it's possible, but with all due respect Jay, mixing old and new on the CVH is asking for trouble, pure and simple. It accelerates the wear on the cam and tappets.
i know what ya saying dude, its not ideal but it can be done, down to the person whos car it is, i only done it as one of my tappets was fooked, as in it was dished on the bottom :o stuck a new set in so i could make it driveable again, lucky for me the cam was fine, and even though i done a oil and filter change, i still managed to score the crank and knock the big end out below it :lol: guess i was unlucky but at the time i was planning a zetect turbo, so "making it drivable" was for the short term to and from work till i got laid off, but now im rebuilding the cvh as i really dont need the power a zetec turbo will make on the small isle of wight :lol: hey ho the fun, still im getting a cam kit to stick in this time, all new stuff :lol:
back to the tappet thing, depending on if a cam and tappets are fitted or just tappets, if the cam is fine and ya wanna do just new tappets, go for it, if ya wanna do a whole new cam kit ( and some motor factors are fairly cheap for whole came kits) depends on how skint/tight ya are :lol:
Postby flyer1 on Fri Feb 03, 2006 10:42 pm
dis ait helpin is there away u can tell without replacing
flyer1
Postby jayrs on Sat Feb 04, 2006 12:17 am
if you take the tappets out and the bottom (cam lob end) isnt damaged then not really mate, they get nosiy, its what they do, replacment is the only way mate for tappets, if ya wanna check the cam ya got to take it out and check it over, as foe big ends, if ya wanna check them let the car idle and get down and with a bar put a end on the sump and ya ear on the other, work ya way along, might have to get a mate to rev it a tiny bit but if theres a bottom end rattle your hear it through the bar.
another this it could be ya water pump, best thing to do is stick the bar on various parts of the engine while its running and check for the sound you can hear but through the bar, just dont get the bar to close to any moving parts, cam belt, pullys etc, it wont be forgiving if it pulls it in!
Postby Excursion on Sat Feb 04, 2006 12:55 am
You have a wire rung block, nice touch but very much overkill for the standard pistons you have there. The idea is simple, the copper protrudes above the deck slightly and forms a tight seal around the fire rings on the head gasket in order to support higher cylinder pressures (more boost basically).
It looks like you have a fresh engine build; the bores look fresh and the pistons look new. I'd like to think that whoever built it didn't skimp on £40 worth of bearings when they had spent £400+ on pistons, although nothing suprises me with 2nd hand Ford engines anymore!
The first thing I'd do is to check the cam lobes with a set of vernier calipers.
Postby flyer1 on Sat Feb 04, 2006 1:51 pm
right striped it all down again tock off lifters then put back on started her up sweet as a nut turned her off , replaced rocker cover ect , started up she was fine after 2 mins started rattling again ,, does any 1 know if an escort rs turbo cam will fit as have new 1 in garage
flyer1
Postby flyer1 on Mon Feb 06, 2006 11:36 am
can any body tell me what they set there time as , im setting it pointer straight up on cam and no1 top dead centre this nock sounds as if valve is tapping piston on revs
flyer1
Postby jayrs on Mon Feb 06, 2006 10:05 pm
set every thing to TDC, the ecu will sort the rest
Postby flyer1 on Wed Feb 08, 2006 2:15 pm
cheers m8t getting a bit pissd off with it to tell truth might just sell it , t had loads spent on it.
flyer1
Postby jayrs on Wed Feb 08, 2006 8:48 pm
could just dump the engine and stick something else in it, zetec, zetec turbo , rs turbo mate
Postby flyer1 on Thu Feb 09, 2006 12:24 pm
could do got 2 rs trbo bottom ends in garage but tel u the truth, cant be botherd any more only bought it to sell cause block i bought it off paid 3.5 k for it and head went so took it off his hands, me own car is rs turbo 2.1zvh with cosworth managment fulll works done to it, just oldies are getting the stiff cause in there garden and only said it would be there a coulpe of days me old an does karting and cant get i and out without a fuss
flyer1
Postby fiestamk3.5 on Thu Feb 09, 2006 9:43 pm
sorry to hijack post
but what gains can i expect if i use a RS Turbo Stage 3 Big Valve Ported Head on a 1.6 8v xr2i
the head has a full ARMED BAYJOO KENT CAM KIT (CVH34)
my xr2i is standard apart from piperx filter , induction kit and peco bb4 back box
also would it be ok to fit a frst head to a standard 2i bottom end
fiestamk3.5
Postby flyer1 on Fri Feb 10, 2006 3:32 pm
dunno m8t is the engine the same compresion wise, pistons ect , is it fiesta rs head or escort if escort ull need an adaptor plate to make it fit then theres turbos
flyer1
Postby fiestamk3.5 on Fri Feb 10, 2006 3:37 pm
ive been offered one cheap and was just going to put it on my xr if it will make a differance not trying to convert it to a turbo just want to use the head
fiestamk3.5
Postby VUK on Fri Feb 10, 2006 3:56 pm
stupid head design if you ask me!
1995 Fiesta SI 3 door, green something, 2L + diesel gearbox in(130mph @ 5,000rpm :o), focus inlet in, + k&n, passed mot without a cat :D < FIESTA FOR SALE! GOT A BMW 528I SE MANUAL NOW :)
http://www.finalgear.com
VUK
