xr2i inlet manifold
15 posts • Page 1 of 1
xr2i inlet manifold
hi im comeing to the end of my rebuild and i ve got the inlet off a xr3i with the p shaped does it make any difference in power between the standard xr2i round port or the turbo p shaped
- stubbsibaby
Re: xr2i inlet manifold
stubbsibaby :hi im comeing to the end of my rebuild and i ve got the inlet off a xr3i with the p shaped does it make any difference in power between the standard xr2i round port or the turbo p shaped
Do you want to explain a bit more, some pics would help?
- freak power
the p-shape inlet is designed for the E F I injectors......if your car is efi then use the p-shaped one...the adapter plate shown is for a non efi cylinder head to accept a efi inlet.. IF your asking about cylinder heads then id say with this adapter plate fitted then there would'nt be any difference between the two
- FRSJON
its the charge air temp sensor (ACT) which in in the right hand side of the inlet as you look at it.
the front bumper i have is a cosworth one
watch him jay hes a numpty
- Priezti
