Xr2i Most amount of Bhp achieved
14 posts • Page 1 of 1
Hi im thinkin of chanign my 1.1 to a 1.6 8v cvh engine and was wondering if they fit straight in and what components other than the enigne gearbox i would need and what can i do to get the most bhp out of it? i was thinkin of bigger but im sure that this will be quick enough if anyone knows or any other easy engine conversion with greater bhp much appreciated was thinkin of rst but finding it hard to come across parts easily and cheaply thanks alot?
- deex
first up dont bother with the cvh.
go for a 2.0 litre zetec. these are quite common engines and power can be pulled out of them quite easily. they are also insurance group 9 so relatively cheap to insure.
- edders
As above, if you're going to do a swap do the 2.0 Zetec as ironically it'll almost certainly be cheaper to insure.
as above. look in guides for erm..... a guide!
- lucasdemoley
Yeah the above replies are correct! You could spend a big heap of money on a n/a 1.6 cvh efi and still be lucky if it's 130 bhp and about 115lb/ft
Look on ebay- last night I saw several Mondeo silver-top 2-litre zetecs going for under £100 There you go, instant 130+bhp for the price of an induction kit and some ht leads for a cvh.... Well nearly!
- jimmyesh
- Your car: Yes
i agree with all the above mate, having started with a cvh, and now having a 2.0 zetec, i would go for the 2.0 every time. my engine cost me £55 on ebay, its only done 85k aswell, the conversion cost me a total of £400 overall
- hb69
- Your car: Fiesta 1.1 LX
I've seen 146bhp from one
- freak power
FRSJON :freak power :I've seen 146bhp from one
from a 2i??? i made 120 bhp from mine and the only thing it didnt have was a chip
Not a xr2i but from a Orion EFI ...Same engine
- freak power
My old engine spec was oversize 1.3CVH pistons, 12:1 C/R, Kent cvh26 can with solid tappets, big valve head machined pockets in pistons, lightened and balanced, 64mm throttle body, machined inlet, magnex 4-1, uprated injectors
- freak power
Its easy but i'm saying that so i really dont know what your like when it comes to things like this.
A modified engine mount
Open up the flywheel hole by 0.5mm on the CVH one and fit to Zetec then it will bolt to the CVH box and use a CVH clutch.
The engine is in now and the rest is just wiring and other little things that you will find info on here about
- freak power
would it may be easier to buy a mondeo 2litre zetec and just swap all the components over like brake callipers discs etc or alot easier to swap just the engine what is the correct gearbox to use as i would prob need new hubs as the drive shafts will be different?
- deex
