XR2i Shocks on 1.3????
7 posts • Page 1 of 1
Does any one know is it possible to put aftermarket shocks meant for a XR2i/FRST onto a 1.3 fiesta or do modifications have to be made, And if so what are the differences ????
Matt
Matt
- MattPym
If i remember correctly.... i was looking into this for my 1.25 fiesta, does it have an airbag? if so its a mk 3.5 therefore you will need to get the shocks from a 3.5 SI model, there were some changes to the shell and/or the suspention of the car in the later years to the mk3, so early suspention wont fit.
hope this helps.
hope this helps.
- mikecozza69
To upgrade your handling ten fold, get some standard (simply because they're cheaper) Si shocks and springs for the front and the back. This wont do much but with the Si struts you will then be able to bolt up an Si/XR/RS front anti roll bar. Also get the lower wishbone crossbrace and it will transform the handling!
You can then later on upgrade the shocks and springs. Or do it at the same time just steer clear of Gmax.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Because they are the biggest pile of poo on the market. Their manufacturing standards are well below par.
- Ollybee
