xr2i transplant.
14 posts • Page 1 of 1
i wanna put an 8v xr2i engine in me 1400 si (cant go for zrtrc only 17 )
how easy will it be? what will i need for the conversion?
any help will be much appreciated.
- Mexi
you will need,
engine, gearbox, loom, ecu, fuel tank,
(as yours is a 1.4, you won't need radiater)
I got it all for sale for a measely sum of £250
not to hard to fit either
The car infront is a Toyota
- The Bruster
- '80s Suprastar
You might be able to get away with just changing the lump and injectors, and having a Unichip (I know...) to adjust the fuelling, although it's a long shot. You've basically got a derivative of the CVH in there already and a lot of the running systems will be common... but Mark Stewart's your man for those answers
- Project
- fiftyoneCL
- fiesta boy
- One big spelling error...
- Mexi
It doesnt go on the qge of the engine - it's the age of the car!!!!!!
ALL CARS AFTER '92 need a cat by law!!!
- xrsi
- XR(ustyAtTheMo)SI
ALL CARS AFTER '92 need a cat by law no matter what engine!!!
This also means that any enigine can be put into a pre '92 car without a cat!!
- xrsi
- XR(ustyAtTheMo)SI
if u can prove the engien is from a car before cats were interduced then ull b ok if not then i dont think it will work as this was one of the reasons the 8v was not used as it would not comply with emission laws set after 92
- fiesta boy
