xr2i turbo
10 posts • Page 1 of 1
xr2i turbo
i have decided 2 turbo my xr2i engine as i brought a spare one at the weekend,its done 64k geniune miles.i have a t2 turbo on the way and a intercooler.looking 4 a cheap t2 downpipe and other bits.what are the other parts i will need 2 do the change?i have a mate what can do the work with me.jus going 2 be an experiment.lol.the only thing my mate dont no is how 2 sort the compression thing out.so need a little bit of help please.
- lachojski2005
turbo
the t2 came up so thought i would use this.just want 2see how this goes.lol.
- lachojski2005
You will need some forged pistons for a start. And the block will need a oil return machining into it, or you could weld a return on the sump. ive had mine machined. You will also need all the frst management side of it, loom ecu ecs. And the crank is diferent between the 2i and frst, but im not to sure if its needed or if the 2i one will do.
- cosmagedon
turbo
my mate says he can change the ecu 2 run the turbo and he said he will weld the return into the sump.part from the caharge carrier is there anything else?are the pistons 2 change the compression?he said somthing about using 2head gaskets or getting a spacer thing 2 sort that but unsure if this would work.
- lachojski2005
You can use the 2i block but you still need the low comp piston's so it's easyer just to stick the frst bolck in there as it's less messing around you can covert the 2i loom but still easyer to just get a frst loom as you will need the sensor's and you will need the ecu intercooler rad pipe work
- j7aoc
turbo
had a bit of look 2 day..... a lad i no is breaking his frst.he brought it 2 put it back on the road cos its had a front end smash but it needs jigging or something so he is breaking.so im having the engine off him 4 100quid with everything.only problem is the clocks read 22000 so its been round the clock.what parts will i need 2 replace?the engine runs fine at the moment.
- lachojski2005
I would just make an offer on the hole car then sell any bit's off i didn't want I would do a compression test on it there only £20 odd pounds to buy and easy to use that will tell you if and piston's are on there way out
- j7aoc
turbo
he wants 300 4 the car but i got no where 2 keep it so jus having the engine with all the running gear ecu loom etc.also throwing me the rear opening quarters in 4 nothing cos im taking the engine out myself.think i can get that done at work 4 nothing.
- lachojski2005
