xr3i inlet manifold on xr2i head
Postby Razer on Sat Feb 15, 2014 2:57 pm
Wil a xr3i inlet manifold fit on a xr2i cvh head, and what do i need to adapt it?
Frst fuel rail or do i need another one
FORD = First On Racing Days
Razer
Your car: MK3 RS1800
Re: xr3i inlet manifold on xr2i head
Postby freak power on Mon Feb 24, 2014 11:36 pm
Razer :Wil a xr3i inlet manifold fit on a xr2i cvh head, and what do i need to adapt it?
If its a EFI inlet from a xr3i then yes
MFI ones will need work to fit, adaptor plate, welded on mounts, machine work for throttle body and sensors
freak power
Postby Razer on Tue Feb 25, 2014 10:20 pm
yes it's a mfi inlet, but the engine is the same right ? both cvh
mmm lot's of work I think..but look a bit different in a fiesta
Razer
Postby freak power on Tue Feb 25, 2014 11:59 pm
The heads are different, you will need a adaptor plate for the inlet and if you want to use the 2i fuel injectors and rail then some machining and welding will be needed
freak power
