Zetec cam gear bolts
Postby Dans mondeo on Fri Jun 07, 2013 9:35 pm
Why the hell did ford ever make them cam gear bolts with a torx on it for. Why couldn't it be a normal bolt head. They are so hard to remove. Does anyone know if an impact gun is good to un do them, it only ever sheers if I'm using a breaker bar
Dans mondeo
Your car: Mondeo 1.8 zetec
Re: Zetec cam gear bolts
Postby Tweek on Fri Jun 07, 2013 11:07 pm
Rounded off a few of these baxtered! It doesn't help when people loctite them in either *sigh*
Your car: VW Golf GTD
Postby AW0L on Sat Jun 08, 2013 9:10 am
get this tool
http://www.toolbench.co.uk/Draper-Exper ... es-P4493A/
and these if you havent
http://www.virtualtoolvan.com/shop/inde ... age&pID=90
and do it with a torque wrench, i've done loads of bolts on the cams without problems with these
but i understand your frustration over it....
AW0L
Postby Dans mondeo on Sat Jun 08, 2013 9:49 pm
Nice one pal. Can anyone buy from tht website
Dans mondeo
Postby AW0L on Sun Jun 09, 2013 11:44 am
i got my cam tool from ebay, still a draper one and the torx sockets i got from work, you will find them on the machine mart website i would think
AW0L
Postby Dans mondeo on Sun Jun 09, 2013 10:36 pm
I have torx sockets. Plenty of them. Just the holder I needed
Dans mondeo
Postby shalon on Fri Jun 14, 2013 12:12 am
The arp replacement ones are 12pt heads instead of the torx
shalon
Postby andymac on Fri Jun 14, 2013 9:48 pm
Larger surface area means you can get more torque on, torx fasteners are very good, though it's usually a good idea to tap the bits in to make sure they site securely (and helps jog the bolts free).
Nothing to see here...
andymac
Elite Pie Master
Elite Pie Master
