Zetec Conversion help?
Postby JoeyBoyden on Mon Jan 09, 2017 11:17 pm
Hi, I am currently without a Fiesta haynes manual, something I need asap but in the meantime does anyone have a manual that could tell me which pin number on a 16v ecu controls the fuel pump relay. My car runs spot on but the fuel pump runs constantly when igntion is turned on as it isn't wired up to a switched earth. Can anyone help me?
JoeyBoyden
Your car: Fiesta Mk5
Re: Zetec Conversion help?
Postby elPaulio on Fri Jan 20, 2017 10:45 am
Hi Joey,
I've uploaded a copy of the Haynes manual to my website (few sections aren't there but the bulk is!).
Here's a link to the file.
http://www.elpaulio.co.uk/Haynes/Haynes.zip
Hope it helps :Q
Paul
Fiesta Si 2.0 16v
Mods: K&N 57i, 2.0 Silvertop, Samcos, GAZ Coilovers, Quaife Straight cut box, Wilwood 4-pots, stripped out track female provider of 'horizontal refreshment'
Planned: GSX-R 1000 ITB's, ST170 4-2-1 Manifold, Megasquirt 2 ECU, OBP Pedal box :)
elPaulio
Your car: Mk3 Fiesta 2.0 Zetec Si
Postby megaflea on Sun Mar 05, 2017 10:04 pm
I downloaded a copy of auto data for the pin outs on the mk3 fiesta ECU plug, very useful for building a plug and play loom (or pin swapping)
megaflea
