Zetec engine strip down with loads of pics
18 posts • Page 1 of 1
had to do this to see how it was going to look :roll: looks s**t with my new bits fitted to a shonky old zetec engine tho
been in the garage tonight stripping down the zetec engine
clutch, flywheel, thermostat housing, coil pack, and manifolds removed
rocker cover, breather and cps remoevd
exhaust cam out
both cams removed
cam followers removed
cylinder head and bits laid out
block all set for stripping
underneath the sump looks like this
oil pickup and windage plate taken off
pistons and rods out
pistons and rods no longer of use to me
looking down the boresat crank and oil spray jets
water pump pulley and crankshaft pulley taken off
the two idler pulleys removed
oil pump removed
water pump removed
crankshaft oil seal removed
main bearing caps
crank resting on the block with no main cap's
crank
with the crank removed you can see the oil spray jets and half of the main bearing shells
oil spray jets
oil spray jets and bearing shells removed, leaving one bare block
if i get time i will strip the head tomorrow :top:
exhaust cam out
both cams removed
oil pump removed
water pump removed
main bearing caps
crank
oil spray jets
RS1600i restore, weld in multipoint cage, t34 zetec turbo
http://www.passionford.com/forum/viewtopic.php?t=130905
- Red16
Well I'll be damned! I'll put my hand up and admit I didn't know the Zetec had oil spray jets like that! I thought it only had spray nozzles on the conrod! Quality! Good pics Ben
BTW that green throttle cable bracket wasn't off a red 300bhp CVH FRST was it??
the 2ltr has the spray jets, as far as im aware the 1.8 doesnt have them.
the green throttle cable bracket was bought from someone on here, i forget who now tho
- Red16
- Red16
whoops double post
- Red16
normal 1.8's dont but the rs1800 lump does have the oil sprays,
brilliant post nice to see so much detail,
very helpful as i told you last night red
- RS rob
bridgend_boy :normal 1.8's dont but the rs1800 lump does have the oil sprays
learn someting new everyday
bridgend_boy :brilliant post nice to see so much detail,
thanks
- Red16
if you dont mind me asking,
where did you get that manny from??
an is it for n/a or turbo?
red xr2i, 2.0 ltr, superchip, magnex system, 2wd cossie brakes on there way- soon to be on throttle bodies and megasquirt
after over a year sat in the yard she gets some attention!
- c8rwt
mate great work as ever,
correct me if im wrong but did you not rescently sell a Zetec that you had done similar work to?
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=116606
turbo application with a plenum like that
c8rwt :if you dont mind me asking,
- FezzR
- God Damn Lazy
what exhaust manifold is that?
6 Point Safety Devices Cage.
- purple_fiesta
sphinx cheers mate
exhaust manifold was bought off ebay, for a n/a focus.
inlet manifold is a rover m16 customised for zetec engine and ofab management.
its from a automatic mondeo estate car
yeah just sold this zetec turbo engine which was built using calibra turbo pistons on standard rods
but my new engine will be a better spec
its a tubular manifold from the states, its intended for a n/a focus but im going to adapt it to suit my t34 turbo
Nilsson :I wonder from which car this engine is
FezzR :mate great work as ever,
purple_fiesta :what exhaust manifold is that?
- Red16
Red16 :going to adapt it to suit my t34 turbo
any reason behing this? my thoughts are why would you build such a good spec engine and use an "old" turbo, sure you would get better results from one of the GT series.
- FezzR
- God Damn Lazy
FezzR :Red16 :going to adapt it to suit my t34 turbo
cost of the gt series turbo compared to the t34 is the main reason, the t34 is still a great turbo (ideal for my planned power output) and i already had a downpipe for it in the garage.
- Red16
i think i know the exhaust manny you bought, how does the down pipe line up with the 1.8 sump pan if you know?
bearing in mind its on a mondeo the actual pan should be at a different place on the engine to the fiesta, so if the downpipe didnt fit the mondy chances are it will fit the fezz.
lots of rambling with a question in there somewhere
- c8rwt
c8rwt :i think i know the exhaust manny you bought, how does the down pipe line up with the 1.8 sump pan if you know?
ive no idea how the downpipe lines up with the sump to be honest with you, as i didnt get one with my manifold.
- Red16
