zetec gear boxes on cvh engines
12 posts • Page 1 of 1
do the cvh gearboxes bolt up to the cvh engine will it fit in my mk3 fezzer 2i cvh.
- MK4 Rick
- Your car: Mk5 Fiesta
Most of the FWD Zetecs used the IB5 which was a slight advancement over the BC box found in the earlier cars. You can get the MTX75 to go in but it's not without ballache.
In an XR2i I would just find a nice S1 or S2 RS Turbo ubit to drop in and enjoy the benefits of the limited slip diff
Oranoco :Most of the FWD Zetecs used the IB5........over the BC box found in the earlier cars.
How do you tell the difference, other than the part code?
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
On a bc gearbox the starter motor is at the front and on the ib5 it is mounted at the rear at the top.
- matty872
Not always bro. iirc some of the IB5 boxes had front as well as rear mount starters depending on what they were from.
ollybee :Oranoco :Most of the FWD Zetecs used the IB5........over the BC box found in the earlier cars.
- Ollybee
- JayC
The IB5 box was brought into use from about 95. Spose it's the luck of the draw whether your Si will have a BC or an IB5 attached to it
xrjoe :Sorry to highjack but i have the opposite problem i have a zetec 2i and a 1.6 cvh 2i for spares, would the box from the 1.6 fit the zetec???
yes
- freak power
