zetec pistons flush with bottom end ? who knows
Postby Razer on Mon Jun 08, 2015 7:28 pm
Who knows if the pistons of a zetec silvertop are flush with the bottom end of the engine or just a bit higher
Mine rs1800 pistons are a bit higher the the bottom end.
Want to know for sure if this is correct after the engine died when driving.
If the need to be flush with the bottom end, what could be the problem?
FORD = First On Racing Days
Razer
Your car: MK3 RS1800
Re: zetec pistons flush with bottom end ? who knows
Postby Smo on Sun Jun 21, 2015 8:49 am
They're usually about 0.5mm above the block (roughly) assuming the block and pistons have never been touched.
Smo
Postby Razer on Sun Jun 21, 2015 8:54 pm
Thanks, i have measurd it, and it is about 0.7 mm outside of the bottom end.
Should be fine
Razer
Postby Smo on Sun Jun 21, 2015 9:07 pm
In what way did the engine die?
Smo
Postby Razer on Sun Jun 21, 2015 9:10 pm
My catalyst did melt and filled up the flexi pipe.
Then 2 bangs and everything stopped working.
Inletpipe was off the throttlebody and it leaked cooliant
Razer
