Zetec-S rear beam and Focus rear discs on the Type-R
119 posts • Page 3 of 4 • 1, 2, 3, 4
As mentioned before, these stub axles add 10mm per side.
We took 10mm spacer blocks off so the track was identical to it was before (20mm wider than standard).
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
it's woth mentioning the thickness of the disk at this point in time as it's 5mm thick so strictly speaking the track is 30mil wider in total.
I am still yet to use my car as i need to replace the windscreen and i have a few gearbox troubles...
Plus the numptys at ford have given me 3 handbreak cables now and i still dont have the right one... Fingers crossed for tomorrow...
then i will let you know what happens when i give the car a thrashing...
- mmogenius
- 2.0 16v Fiesta RS Turbo
If you're still fighting handbrake cables, try the FRP one. If you're fighting Ford parts dept staff, then good luck to you!
- Jon_mk4
RS2000 handbrake cable fitted today. A tad long but nothing a bit of tweaking won't sort out. Need to route it slightly different as it's shorter on one side.
Rear flexi hoses replaced with ones from the front. A bit long but will do until braided ones are made up.
Bled it all up and tested
Slightly longer pedal travel.
The back won't step out and it wouldn't swap ends despite locking the fronts up in both the wet and the dry.
No noticeable improvement in braking really (it was mental stopping power before though ) Maybe a little less nose dive.
The rear beam
WOW!!
Such a difference. Grips like glue round roundabouts and corners, with the standard beam you can feel it begin to want to go, this is much more solid.
Rock solid stable through sweeping corners at high speed, no creeping motion or instability like the std one.
This + IH lower arms = awesome.
The rear beam
WOW!!
- AdrianFRST
just been on the phone trying to get the beam.....
right.... is a puma or ka one the same?? every one kept telling me i9t was and im like... no not as stiff as a zetec s one?
who is right?
who is right?
- xrsi
- XR(ustyAtTheMo)SI
Ka / Puma / mk4 and early mk5 are all different to this one and will require mods to the shocks and may not fit the discs.
As stated you need a 2001 model mk5 one.
- AdrianFRST
Oh btw Ade, late mk4's have the right beam, and as far a I'm aware all mk5's should have the right beam.
You can tell the beam you need as it will come from a car with the square headrests (revised mk4 1999 V plate - ciggarette lighter on the dash as apposed to ashtray).
Just one question left...
Is it possible to place 13' weels with this modification? or no?
because in belgium, we have a sort of MOT, and can't pass with weels bigger dan 14'. I have 15' but change them each year to go at the MOT (replace my 15' with 13'), If I have to change all, just for MOT... il will be too much work each time...
- metm
I *think* they're 250 or 251 mm... something around that mark. Bigger on the ST and RS versions (270mm or so) which means you can't get any of them inside 13"s.
Getting a cheap set of 2nd hand 14" steels and respective tyres just to get you to the test might be a good move... I'm sure it won't set you back too much, and it would also allow you to run 260 mm discs at the front with a RS2k or Mondeo setup.
Gonçalo D.
Gonçalo D.
- voorhas
- Location: Portugal... and no, that isn't a Spanish city
Excursion :I see your from portugal, where in Spain is that??
Look whos talking... Lincolnshire sounds like a place thought up by Mr Tolkien... r u a hobbit, by any chance? Stop picking on me! You bad, bad man...
Gonçalo D.
- voorhas
1.1 has solid front discs - 240mm or something
A straight swap would be 260mm discs and calipers from an Escort RS2000, Puma or Zetec-S
Those apparently all fit right on and would produce much better stopping power
- Stoned
sorry to top the post but got a couple of questions. i want to do this conversion on my mk3. i have g-max -60mm kit on xr2i 8v 13`s. can i use zetec-s rear drums instead of discs? also what is it exactly that i need? and how much roughly am i looking at?
At least i dont drive a saxo!!
- Marc D
- Your car: fiesta xr2, xr2i and rs turbo
pollocks :didn't the zetec s come with disks on the back any way ?? if so can't u just use them instead of doing the focus brakes so therefore u wouldn't have the extra track so no arch/wheel touching problems lol
Nah no fiesta had the rear disks.
- MikeyXR2i
MarcD: To actually answer you Q, you should be able to bolt a mk5 rear axle and drums straight on.
All you should need is a late mk5 fiesta rear beam with drums still on and that's it!
Should cost less than £50, mine was £35.
Despite what people say i cannot find ANY difference between my std mk5 rear beam and my Zetec S rear beam. No difference in stiffness at all, it looks identical.
- Thumbs
Morning Guys,
Got a few questions on this conversion which i hope someone can help with, sorry to bring up an old post.
A friend of mine has been ringing breakers to try and get hold of a Zetec-S rear beam and he's been told that they did two phases, Phase one has drums and phase two has discs.
Now, my first question, can anyone confirm that this is true and that the phase two beam will still directly bolt to the mk3.
Do the standard FRST wheels fit this phase two setup?
Thanks for any help, i may have mroe questions so be warned
Matt
Matt
- StreetDragster
StreetDragster :Morning Guys,
Matt
Ive now been informed by a couple of breakers and a member off here that there is no Zetec-S's with rear discs. The breaker that told me about the two phases must have been mistaken .
So it looks like we're back to square one lol. Zetec-S rear beam with Focus or RS2000 rear discs
I'll get searching again
- sweeny
So, lets say i've got the following situation-
FRST with GAZ Coilovers
and i want to fit a Zetec-S rear beam and retain the Zetec-S's Drum brakes.
1) Would the wheel sit in a different place?
2) Would the dampers bolt straight to the beam?
3) Anything extra/different needed to connect up the drum brakes? (like can i use FRST cables and FRST goodridge braided lines)
Thanks for any and all help, i want to improve the cars handling, but i'm not to concerned about fitting rear discs, i find the drums more than fine for me (Focus ST170's at the front)
Matt
Matt
- StreetDragster
StreetDragster:
1, The wheel would sit in a different place, the Z-S drums are narrower than FRST drums, so you'll need spacers.
2, The dampers will bolt straight onto any phase 2 fiesta rear beam (all phse 2 rear beams are identical)
3, Don't know anyone who has actually put mk5 drums on mk3, but from memory the brake pipe fittings and h/brake cable fittings are in the same position. Don't know if fitments are the same tho'
Post up if you do the convo. Nice to know if it can be done.
- Thumbs
Cheers Pal,
I'm looking to do the conversion drums only, and James will be doing the conversion with discs. Will let you know whats easiest!!
Matt
Matt
- StreetDragster
