Zetec S rear beam
14 posts • Page 1 of 1
Zetec S rear beam
Can some one tell me how I tell the difference by eye between a standard mk5 rear beam and a zetec s rear beam? I know the zetec s rear beam has extra bracing but if some one has pictures of both and can highlight the differences I would be very grateful
- Makaveli
Re: Zetec S rear beam
IIRC the ZS beam is wider aswell, but that mite be all mk 5 beams. The extra bracing is the only other difference, the webbing at the corners is wider
- Ruishy1
Cheers fella. Do you have any pics so I can see how much wider the webbing is so if I see a beam in isolation I can tell if its a zetec-s or normal one
- Makaveli
did you measure to see if it was wider ? as i dont think you can notice 10mm either side by eye
- Ruishy1
Never measured it no, But 10mm is quite a lot and I would of noticed it. Especially with the scrubbing as it used to do it at particular places etc and it never did it any worse!
i know mate, i work in aircraft, 10mm is easy to spot, try noticing a rivet that is 4 thousands of an inch under
BUT ive heard of many people saying they are wider, i wonder where the info came from ?
Something i will investigate if i get the chance
- Ruishy1
- Makaveli
SportKa I think!
Pretty sure ZS beam is no wider!
I read somewhere that rear beams with the fork type mounting had 10mm spacers as standard fitted to the rear which probably makes up for the extra length.
Not sure how true this is though?
- Jam0r
I know someone thats making independent rear beams for the Fiesta They are really only for track days as you will need a custom exhaust and a fuel cell.
- freak power
Very sweet, can you post some pictures up? What sort of price would you be looking at? As I'd be very interested in that in the long term
- Makaveli
I'm working on a RS2000 one right now and will post pics of it when done
Price will be about £500+
- freak power
It will look something like this one on a Maxi RS2000 Rally car
The Anti roll bar you will have to sort out yourself from parts from rally design
- freak power
