zetec s rear beam
25 posts • Page 1 of 1
zetec s rear beam
right have used the search for fitting a puma rear beam and it says the zetec s one is better to fit!
just a couple of questions b4 i lay out some money for one!!!
DOES IT COME with a rear ARB?? and secondly.... does it bolt straight on and the mk3 shocks bolt straight to it??
wanna fit the rear disks b4 summer and if im gonna do it i may as well fit a better rear beam than a 1.1 item!!
so any help would be great!!
thanks
James
thanks
James
- xrsi
- XR(ustyAtTheMo)SI
Dunno if it helps but I got a z-s and hi-spec brakes do a rear disc conversion for about 650+vat, so if you get the beam you could get the discs ?
If you want me to have a look at anything then just say and me mk3 is still at home so i could compare !!
Cheers Dan
Cheers Dan
- DorsetZS
Zetec-s and puma beam not need rear ARB, stiff enough already built in. I wonder if all mark 5 beams are the same??
zetec-s beam shock configuration makes it easier to fit than a puma one.
chk if a mk3 rear disc convo will fit it, as i thk they changed the stub axle bolt locations, 'i think'<<
and can some1 see if mk3 poly bushes for the void mounting will fit a zetec-s??
- fiesta_fras
- Elite Poser
thats quite handy knowing!!!!
will go get me a rear beam this week then!!
should think that the mounting bolts would be in the same place!!!
- xrsi
- XR(ustyAtTheMo)SI
I've fitted a Zetec S beam to mine, think all Mk5's are the same. Everything lined up and bolted straight on to my Mk3.5 dunno if Mk3 is the same, don't see why it wouldn't be
As Fras said, the stub axle bolts are in a slightly different position so you also need Mk5 stub axle/backplate/drum etc, as well as Mk5 brake hoses
It is much stiffer than the Mk3 one and doesn't need an ARB although the Mk3 ARB will fit without any modification if you want to stiffen it up some more
- FRS_Steve
steve - i wanted to fit the rs2k rear disks to this!!!
would the bolts be in a diff place to the stub axels of a 2k do u know??? :S
- xrsi
- XR(ustyAtTheMo)SI
I had a zetec-s rear beam ages ago until I tactically sold it.
Any beam from a mk4.5 will fit. Judge the handling for yourself - most people assume a lowered and hard ride = good handling. Alas it' far from the truth mate. Depends what you are looking for really?
I personally reccomend standard FRST or mk3.5 RS1800 suspension and a zetec-s rear beam - it's the best you'll get without a weld-in roll cage.
Go for it dude.
Go for it dude.
blimey i was right about somethg
if the rs2k ones fit a mk3, im am half sure they wont fit a mk5 beam,
any1 confirm this, mark, u have rs2k convo, does it fit a mk5 beam?
- fiesta_fras
- Elite Poser
MikeyXR2i :Im sure the Mk5 R2000 beam is to wide for the fiesta. I measured the beam on a RS2k and it was way to wide.
IM ASKING ABOUT FITTING A ZETEC-s REAR BEAM WITH THE RS2k STUB AXELS!!!!!!
- xrsi
- XR(ustyAtTheMo)SI
If RS2K stub axles line up with the holes in a Mk3 beam then they wont line up with a Mk5 one unfortunately Maybe it would be possible to get some adaptor plates made up? Sorry I can't be much help on this as I haven't got rear disks yet...
- FRS_Steve
- AdrianFRST
- Baby Battle Scratch
- Your car: ..? Pretty car..!
Car: 2010 Ford Focus RS
- AdrianFRST
- Phil Si
Car: 2000 BMW 330 Ci
Yep, so why do the likes of Citroen go to the trouble of producing two braking setups for the Saxo? One with discs and one with drums?
Surely there must be an advantage to rear discs or they wouldn't bother?
- AdrianFRST
You will not notice the difference on the road. All the advice I have been given about my rally car is not to bother with discs as drums will be adequate.
The racing XR2s disconnect their rear brakes deliberately although the scrutineers don't like it!
Cowspeed
- XR2iT
xrsi, if ur still after a zetec-s rear beam that will take mk3 brakes inc rs2k sduff, PM me
- fiesta_fras
- Elite Poser
