Zetec Throttle Body
20 posts • Page 1 of 1
Do you know somthing I don't???<br>injector wise??? 'cos i'll probably need help on the very same subject in the near future.<br> BTW it was mentioned on the XRownersclub BB that 130ps copies are available, but not sure where from.
- muffking
I got my 130PS throttle body off a '94 2.0 Mondeo. Cost about 40-50 quid, forget exactly. It was ordered from a scrappy in lancs somewhere. If you're desparate I'll try and dig out the name of the company.<br><br>As it's off the mondeo inlet manifold the throttle cable linkage needed swapping over and part of the linkage needed drilling out to accomodate the bigger spindle on the 2.0 t/b. I'd imagine one off a RS1800 would simply swap over! just in case you didn't know.
- Andy_XR2i
I've already got the mondeo one - but it looks like a mission to get it to fit so I am taking it back<br><br>cheers for the help<br><br>Mike.
- Mike Gurney
Mike: I think the manifold that ian used to use was a moddified Rover Turbo manifold & yes it used FRST type injectors. For some reason I don't think he uses them any more.<br> Are you after using the 130ps body for yours? If so, which injectors?
- muffking
Muffking<br><br>My 2.1 16V uses the zetec inlet manifold and special side fed injectors - Ians conversions use a different inlet manifold, and end fed injectors (you can use the FRST beige injectors)<br><br>If you use Ians inlet manifold you will not need to worry about the Zetec Throttle body cos he uses the FRST one.<br><br>Hope this helps<br><br>Mike<br><br>Drop me a line if you need more info.<br><br>
- Mike Gurney
Muffking<br><br> Yep the throttle body is for mine - the injectors are special motorsport jobs that Ahmed gets hold of<br><br>Mike.
- Mike Gurney
Andy - I have 2 throttle bodies <br><br>a 1.8 one and a 2.0 mondeo one<br><br>The mondeo one will only fit the later inlet manifold (not the efi ally one)<br><br>drop me a line if you are interested.<br><br>Mike.
- Mike Gurney
Mark, course! otherwise your t/b I've got wouldn't fit your mk3 manifold! doh!<br><br>In that case Mike, if you want to post a price and I'll check it out with the guy who wants it, make sure he'll go with the price. Does it come with a throttle position sensor bolted on?<br><br>thanking you squire, Andy
- Andy_XR2i
Every kind of mondeo T/B to date can be used on the Fiesta <IMG SRC="http://www.v8fiesta.co.uk/ubb/smilies/biggrin.gif"><br><br>
Cheers guys - finally got the correct one !!<br><br>The two throttle bodies i've got left are<br>a 1.8 one and a 2.0 mondeo - both are fully complete with the TPS intact<br>£40 each<br><br>e:mail me on mike.j.gurney@sb.com
- Mike Gurney
Oh crap its the wrong type !!!!!<br><br>UUUURRRRGGGGGHHHHHHHHHH<br><br>another late mondeo one not the type I need<br><br>Help - somebody must have one somewhere
- Mike Gurney
What exactly are you after m8?<br><br>All the mondeos 93 to present use the Zetec-e engine and the t/b's are pretty much identical!<br><br>Are you after a fiesta and early escort 130ps type?
2000_16v_Turbo<br><br>yep I'm after a fiesta or early xr3i 130 ps type<br><br>can I mod the mondeo one so the linkage will fit from the 1.8 one i've got - I've tried but all the dia's are different<br><br>any idea's<br><br>Mike.
- Mike Gurney
Cheers Mike, just mailed you about it.<br><br>If it is the RS1800/1.8 130PS t/b you're after I think you'll find they share many properties with rocking horse s***.<br><br>Someone's gotta have one though. You need to find someone who's only just got the car for breaking I reckon as I doubt anyones got a 130PS 1.8 sitting on a shelf.<br><br>Andy
- Andy_XR2i
Finally got it sorted - due to the help of RichardPON<br><br>We made a new throttle body with bits from the 2.0 and the 1.8 linkages - it was a bit of a Bic™ but it works<br><br>Mike.
- Mike Gurney
